vario
My garage: 1942 WC-54 Ambulance
Re: WWII Dodge Links and Database ( Sticky )
Post by vario »
Hi,
here are the pics Heinz tried to upload:
Greetings from Germany
Ulrich
johngbg
Private
Post by johngbg »
Found a WC-53 with:
VIN: 81586332
Hood: 2089456
and it seems to be correct.
juan15
Post by juan15 »
Hola John,
Yes, it can be correct.
It would be very interesting to see the B.C..
If it is correct, your vehicle was ordered with the contract number: W-374-ORD-2840, W-398-QM-DA-521.
Under that contract 688 units were delivered in 1942 and 84 in 1943.
Your vehicle is from the end of November 1942?.
Regards,
Juan.
juan15
Post by juan15 »
Hola Ulrich,
I think that the body plate is not correct, but I'm not sure..
WC-55, VIN 81 530310.
The two B.C. closest we have are:
81 529912, 14 may 42...body nº 4728
81 530904, 5 jun 42,,,body nº 6418.
Although in the WC-55 model there is a lot of confusion in the sequence of numbers.
However it would correspond a body tag 5000, for example. Although I do not rule out that it could be number 2621.
What strikes me is the 4290.
In all B.C. we have the model WC-55, the body model is 86. Therefore the body tag is 4286.
But I may be wrong and it corresponds to 4290, which means that the vehicle was delivered as: Bucket seat body.
Therefore I ask for help:
To the owners of model WC-55, what body tag does the vehicle have?
Regards,
Juan.
pierino
Private
My garage: 1941 Ford GP
1942 Ford GTB, matching #'s
1943 Huffman model 81
1943 R.I.A. Hand Cart M3A4
1943 Willys MB
1943 Highway Trailer K-38
1944 Ford GPW, matching #'s
1944 Cushman 39G
1944 Harley WLA
1944 Converto Dump 1/2 Ton
1944 VW TYP166 Schwimmwagen
1960 Willys MB-T
1943 Stinson L-5 *SOLD*
Post by pierino »
my friend's truck: WC-51 s/n 81722407 delivered aug 11th 1944
usa number unknown... any suggestion?
(it should be somewhere half the way between 2235399 and 2266424 ... around 2249XXX)
thank you for help!
maurizio
pierino wrote: Wed Jun 02, 2021 9:43 am my friend's truck: WC-51 s/n 81722407 delivered aug 11th 1944
thank you for help!
maurizio
That seems about right Maurizio. Unlike the smaller quantities of earlier trucks, the later WCs were produced in big batches, and WC-51 / WC-56 split is not shown for a chassis batch, so you can only approximate.
pierino
Private
1943 Willys MB
1944 Cushman 39G
1944 Harley WLA
1960 Willys MB-T
Post by pierino »
thank you Gordon... hopefully someone else will help to have a more detailed guess...
I can help instead with details of my "under restoration" WC-21, for which I also have the build card:
s/n 81501588
DoD 11 6th 1941
eng # T-215-6644 ( I don-t own the orig engine, but a later # T-215-12430, probably casted on nov 14th
USA # W-235959 both on cowl and cargo body
body number 19573
ciao
maurizio
juan15
Post by juan15 »
Hola Maurizio,
Possibly it is from the production order T-10447, contract 374-6322, which in 1944 21,549 units were manufactured (+ 212 units year 1945), and with military registration from 2 235 399 to 2 257 159.
We have a B.C. very close to your car, the 81 722 458, of August 11, 1944 and with Sched. 27212.
81 722 407, so doing a subtraction, we would have a Sched. No. 27,161. Agree?.
All this is just numbers and assumptions of mine, the reality I do not know.
So far everything is clear, but the following is a little bit, just a little bit more complicated.
We have 18,966 units manufactured under order T-8351 beginning with Sched 1,001. Therefore, it is my theory, Sched 19,967 is the last of this manufacture.
So your manufacturing order, T-10447, would start with Sched No. 19,968.
Since your car possibly has Sched 27,161, it would be vehicle number 7,194 of this build order (27,161-19,968 = 7,194).
Therefore your military registration could be: 2 235 399 + 7 194 = 2 242 592 [/ b].
All this is possible ...
Posiblemente sea de la orden de producción T-10447, contrato 374-6322, que en 1944 se fabricaron 21.549 unidades. y con matrícula militar desde 2 235399 a 2 257 159.
Tenemos una B.C. muy cercana a tu coche, la 81 722 458, del 11 de agosto de 1944 y con sched. nº 27212.
81722407, por lo que haciendo una resta, tendríamos un Sched. nº 27.161. ¿De acuerdo?.
Todo esto sólo son números y suposiciones mías, la realidad no la sé.
Hasta ahora todo claro, pero lo siguiente es un poquito, tan sólo un poquito más complicado.
Tenemos 18.966 unidades fabricadas con la orden T-8351 y que comienzan con el Sched nº 1.001. Por lo tanto, es mi teoría, el Sched nº 19.967 es el último de esta fabricación.
Por lo que tu orden de fabricación, la T-10447, comenzaría por la Sched nº 19.968.
Como tu coche, posiblemente, tiene la Sched nº 27.161, sería el vehículo número 7.194 de esta orden de fabricación (27.161-19.968=7.194).
Por lo tanto tu matrícula militar podría ser: 2 235 399 + 7 194= 2 242 592.
Todo esto es posible...
Saludos,
Juan.
juan15
Post by juan15 »
Maurizio,
If I do my calculations for your WC-21, I get the military registration 235 967 and you say it is 235 959.
Therefore my calculations may be correct. Just a difference of less than 10.
Si hago mis cálculos para tu WC-21, me sale la matrícula militar 235 967 y tú dices que es la 235 959.
Por lo tanto mis cálculos pueden ser correctos. Tan sólo una diferencia menor de 10.
Saludos,
Juan
