pierino wrote: ↑Wed Jun 02, 2021 9:43 am
my friend's truck: WC-51 s/n 81722407 delivered aug 11th 1944
usa number unknown... any suggestion?
(it should be somewhere half the way between 2235399 and 2266424 ... around 2249XXX)
thank you for help!
maurizio
That seems about right Maurizio. Unlike the smaller quantities of earlier trucks, the later WCs were produced in big batches, and WC-51 / WC-56 split is not shown for a chassis batch, so you can only approximate.
thank you Gordon... hopefully someone else will help to have a more detailed guess...
I can help instead with details of my "under restoration" WC-21, for which I also have the build card:
s/n 81501588
DoD 11 6th 1941
eng # T-215-6644 ( I don-t own the orig engine, but a later # T-215-12430, probably casted on nov 14th
USA # W-235959 both on cowl and cargo body
body number 19573
Possibly it is from the production order T-10447, contract 374-6322, which in 1944 21,549 units were manufactured (+ 212 units year 1945), and with military registration from 2 235 399 to 2 257 159.
We have a B.C. very close to your car, the 81 722 458, of August 11, 1944 and with Sched. 27212.
81 722 407, so doing a subtraction, we would have a Sched. No. 27,161. Agree?.
All this is just numbers and assumptions of mine, the reality I do not know.
So far everything is clear, but the following is a little bit, just a little bit more complicated.
We have 18,966 units manufactured under order T-8351 beginning with Sched 1,001. Therefore, it is my theory, Sched 19,967 is the last of this manufacture.
So your manufacturing order, T-10447, would start with Sched No. 19,968.
Since your car possibly has Sched 27,161, it would be vehicle number 7,194 of this build order (27,161-19,968 = 7,194).
Therefore your military registration could be: 2 235 399 + 7 194 = 2 242 592 [/ b].
All this is possible ...
Posiblemente sea de la orden de producción T-10447, contrato 374-6322, que en 1944 se fabricaron 21.549 unidades. y con matrícula militar desde 2 235399 a 2 257 159.
Tenemos una B.C. muy cercana a tu coche, la 81 722 458, del 11 de agosto de 1944 y con sched. nº 27212.
81722407, por lo que haciendo una resta, tendríamos un Sched. nº 27.161. ¿De acuerdo?.
Todo esto sólo son números y suposiciones mías, la realidad no la sé.
Hasta ahora todo claro, pero lo siguiente es un poquito, tan sólo un poquito más complicado.
Tenemos 18.966 unidades fabricadas con la orden T-8351 y que comienzan con el Sched nº 1.001. Por lo tanto, es mi teoría, el Sched nº 19.967 es el último de esta fabricación.
Por lo que tu orden de fabricación, la T-10447, comenzaría por la Sched nº 19.968.
Como tu coche, posiblemente, tiene la Sched nº 27.161, sería el vehículo número 7.194 de esta orden de fabricación (27.161-19.968=7.194).
Por lo tanto tu matrícula militar podría ser: 2 235 399 + 7 194= 2 242 592.
