What thickness for WC 53 roof panel
- My garage: 1942 Dodge WC 53
Hi folks,
what is the correct thickness, ormwhat thickness dod you use, for the roof panel on the WC 53 please?
Re: What thickness for WC 53 roof panel
Evening Ian
I use 1/2" MDF for the cross bearers, sanded down at the ends to give a slight bow on the roof, and standard hardboard which is about 1/8" for the roof panel itself, plus a layer of vinyl which will add another 1/16" or more to the thickness, plus paint.
That combination has worked well on the couple of roofs that I've done, WC 53 and WC 36, plus it is cheap and easy to replace if damaged.
Thanks Gordon. I have some ply wood that I was considering using and size is just about perfect. Did you glue the MDF into place or screw them through the bearers?
I will definitely put a slight bow in the panel and will waterproof the canvas once it's in place.
what did the factory use?
Hi Kaegi,
Sorry but I don't understand your question.
According to the manuals they used "Masonite" which I understand was very similar to modern hardboard but slightly softer, so probably slightly thicker too.
There are a lot of factors to that roof, maybe I should cut and paste from my Carryall roof article if I can find it.
G,Day Gordon . Boy i thought our Polatices was bad PM . Rudd And Gillard were 2 absolute . Richard craniums {Dick Heads } . Then we had Abbott . Our polatics , pales into insignificance compered to your,s at the moment . Chuck in Trump ,for good measure, and we are all up the creek without a paddle . Ray
Question ? .How do you know a polly is lying .. Answer his mouth is moving . . Ray
... or hers, Ray, or hers ...
Good job we have given up on all mention of politics on here, eh?
I recall now thanks. i had read that long ago.Gordon_M wrote: ↑Mon Oct 07, 2019 8:02 amAccording to the manuals they used "Masonite" which I understand was very similar to modern hardboard but slightly softer, so probably slightly thicker too.
