Try hood number W-2616081958 M274 wrote:I have WC-51 frame number of 81560119. It was overhauled after the war and the body tag on the cowl does not match the build card I got from the Chrysler archives (I assume the cab was swapped). According to the build card, my original body number was 17557, the engine number was T214-31790, and it was built Aug. 7, 1942. The hood number is long gone.
WWII Dodge Links and Database ( Sticky )
- divingrocks
- Master Sergeant
- My garage: 1942 WC54 Project
1943 WC54 Donor - Location: Ventura, CA
Re: 3/4 Ton Database of 430 known
- Blacktom
- My garage: Steyr 380k, Steyr 380TLF, Dodge WC52
Re: 3/4 Ton Database of 423 known
divingrocks wrote:I have calcualted hood numbers for you:Blacktom wrote:Hello,
I own:
WC 52 Frame # 81734983 engine # T214 166295 ex Austrian Army
WC 51 Frame # 81716025 engine # T214 E21024 ex Austrian Army
and the Wreck of a
WC 52 Frame # 81743046 Hood # 2304319 S
greetings from Austria!
Tom
51 2247660
52 2270080
Do you know the body tag numbers for these trucks as well?
Thank You for the Hood numbers, but I'll keep the WC52 in the austrian army style, its been rebuilt in 1953 in the Karlsfeld Ordonance depot anyway, but I'm thinking about painting the WC51 in the original way.
The body tag on the WC 52 is missing, but the number on the WC51 is 4290-130297
the number of the WC52 wreck is 4290-157124
Thanks for the suggestion!divingrocks wrote:Try hood number W-2616081958 M274 wrote:I have WC-51 frame number of 81560119. It was overhauled after the war and the body tag on the cowl does not match the build card I got from the Chrysler archives (I assume the cab was swapped). According to the build card, my original body number was 17557, the engine number was T214-31790, and it was built Aug. 7, 1942. The hood number is long gone.
Joe
Thanks,
Joe
1942 Dodge WC-51 (from Norway)
Other M-Series Vehicles
Joe
Re: 3/4 Ton Database of 432 known
Two more from down under .81618168 a Wc52 and 81742284 a Wc51 .There were no DoD ,s or hood numbers that were correct . Ray
- divingrocks
- Master Sergeant
Try 2164020 for the 52 and 2255926 for the 51Ray Edsall wrote:Two more from down under .81618168 a Wc52 and 81742284 a Wc51 .There were no DoD ,s or hood numbers that were correct . Ray
- My garage: VC-1 Command Car, WC-6 Command Car
M3A1 White Halftrack, WC-56 Command Car
GP Ford, , 1-Ton Nash Trailer, WC-22, WC-26, WC-11 - Location: Kentucky
Re: 3/4 Ton Database of 551 known
WC-56 Ser# 81629398
Sanding on my hoods today, I found the orginal hood numbers. USA 20181435. This is not what is on your list.
Thanks PhilH
Thanks PhilH
VC-1 Dodge #8640391 April 1940
WC-6 Dodge #8666165 ?? 1941
WC-11 Dodge #8676533 April 1941
WC-22 Dodge #81505598 Dec 1941 Sold
WC-26 Dodge #81512402 ?? 1941
- divingrocks
- Master Sergeant
Well, it appears your truck is an early 43 and the rego is for a late 42...but but both are borderline so who knows?Phil H wrote:WC-56 Ser# 81629398
Thanks PhilH
- My garage: 1944 Dodge WC-52
Re: 3/4 Ton Database of 733 known
something went wrong in the list sorting on the first page I think, this one (mine) needs to be moved up the list a bit :
81723127 WC52 21????? 08/19/44
/Peter
/Peter
1944 Dodge WC-52
- divingrocks
- Master Sergeant
Thanks for pointing that out, it will be in it's proper location when I update again!
OK Heres my # WC51 81776119, body 4290-13112. 4-12-45. WC56 81634611 , body 4219-21020. 9-42. do these # make sense?? Thanks The Dodge Boys.
- divingrocks
- Master Sergeant
Unless the 51's body tag number is missing a digit, the body is an early 43 and the chassis a 45The Dodge Boys wrote:OK Heres my # WC51 81776119, body 4290-13112. 4-12-45. WC56 81634611 , body 4219-21020. 9-42. do these # make sense?? Thanks The Dodge Boys.
The 56 is a late March 43 production and I suggest a registration number of 20471233 if you need one.
- My garage: 1942 WC53 Carryall #81627361
Body Tag #4249-1289
Ex Supreme Surplus
Ex Steve Quick
Purchased in 1978
Re: 3/4 Ton Database and Helpful Links
Got my build card today,please add information to database.
Ser # 81627361
Build Date Feb 15 1943
Engine # T214-91598
Body Tag # 4249-8445
Since my carryall was built in the last contract of 465 I wondered how
the original body tag screwed to the front door frame was so low 4249-1289.
Were body tags switched during post war norwegian rebuilds ?.Were can I find
or who makes repro zinc body tags. Regards Joe
Ser # 81627361
Engine # T214-91598
- divingrocks
- Master Sergeant
Norweggian rebuilders committed many forms of heracy...putting older bodies on later chassis. I have noticed that the '42 bodies seem to have better survived the ravages of time (perhaps they used cheaper body steel beginning in '43)cappy42 wrote:Got my build card today,please add information to database.
Ser # 81627361
Engine # T214-91598
Hola Divin,
I need your help.
I have a friend in Mexico, which has a WC-54, nº 815 62 766. I think the car will be 22 of august 1942, + -1 week.
You could confirm the date and tell me the number of hood, please?.
I'll tell him to request a photocopy of B.C.
Thank you very much,
B.R. Juan15
I need your help.
B.R. Juan15
- divingrocks
- Master Sergeant
I think the date sounds about right, a hood number would be about 712084 +or-50
