"Foot Starter" push rod grommet
I hope I am using the correct term, but the question deals with the foot starter push rod. What I am talking about is the foot starter push rod that goes through the fire wall to starter. It is the one that is pushed to start the WC.
Now is there a rubber grommet on/in the firewall that this passes through? I have about 1/4 to 1/2 inch play. Which can and does make starting a real pain in the ass! A rubber grommet would make sense and take up the play in the rod.
I was looking at the photos of Marks and his WC 55 and it looks like there is a rubber grommet in/on the firewall.
Thanks for being understanding on my numberous questions. But I want to do this right! And my ability to speak Manual/TM is limited
Jim M
Jim M
Starter grommet
Mark,
You are a life saver! Had looked at the firewall and saw the hole assuming that the whole had become enlarged from use over the years. Saw the pictures on your web site for your WC 55 and saw what I had hoped was some type of grommet.
Did not look forward to trying to weld the hole smaller the grommet makes it a whole lot easier!
Now just to try and track one of these little devils down
Thanks again!
Jim M
Thanks again!
Jim M
Pedal
No bushings or grommets were used for this application. The original starter pedal has a casting, and over the years, wears out. I have just reproduced new starter pedal assemblies to fix this problem. Correct for 3/4 and 1.5 ton WC series trucks.
http://www.midwestmil.com
John
John
Yard
Yes, it is still there. Not much left however. There are some nice Ford G8T type trucks there. All the tactical truck stuff has been scavenged out by me and a number of other folks. A bunch of International parts trucks there. All big stuff like M5H6's.
Foot Starter Rod
Thanks for the words of advice! Will go out now armed with this knowledge and tackle this problem (I hope )
Mark,
Thanks for the pictures. Seeing what I am supposed to be looking for makes a difference. Some times the TMs not all that helpful.
Jim M
Mark,
Jim M
Foot starter rod
I was finally able to get out front and check under the hood of the WC to see what the problem might be, armed with the words of advice from the group.
It was a broken casting around the push rod that was the problem
Now armed with the needed part, I can replace this trouble causing piece and start fresh with the WC (no pun intented).
Thanks again to all for their advice and help!
Happy Holidays!
Jim M
Happy Holidays!
Jim M
[quote="Ugg"]John:
"I just read about you in Supply Line, about a junk yard you found in NM. Is it still there?"
If that's the yard in Gallup, there isn't much left to get. I took a pile of WC 53 stuff to a collector in Albuquerque a year or so ago on my way back from Montana, and saw some of the vehicles he had collected from there. He had a couple of very decent WC53's that he had aquired from Gallup earlier, and had just picked up two GTB's and a cool multi-passenger, stretch military limosine the same day I delivered the parts. Not much was left of interest now, from what he tells me.
