origionaly this add was placed in the ww2 dodge forum
wc 52 drivetrain parts for sale
for sale as a complete package
engine 230 cu in. ran two years ago when vehicle was parked. Turns over includes intake/carb/ex manifold/oilfilter/ distributor. Minus starter h20 pump and generator. Extra intake and exhuaste manifold, rusty but useable. extra fuel pump. No numbers stamped on pad.
flywheel,bellhousing, clutch/pressureplate. throwout bearing dust cover
frame crossmember and brackets.
transmission,complete with park brake and mechanism,intermediate driveshaft transfercase w/linkage
front drive shaft, usable but questionable, with small u-joint retaining hardware
rear driveshaft with small u joint retaining hardwere
front leaf springs, left and right, with shackles
front shock absorbers left and right with hardware
front axle, complete drum to drum, u-bolts, clamp plates, steering arm,drag link,pitman arm. tie rod ends, tie rod assembly,lug nuts.
rear axle, complete drum to drum with clamp plates, lug nuts
rear shock absorbers left and right
three rims, two are combat type
steering gear box, column and steering wheel
brake master cylinder, piston rod and brake pedal assembly and linkage
clutch pedal assembly and linkage
sheet metal
left floor, transmission cover, right floor , gas pedal
engine hood and side covers usable but abused
radiator, radiator core support
front fenders, grill and headlite grills
1. All parts have been taken out of a vehicle that ran and drove to its present location
2. Everything is sold together as a package
3. Parts are located in South Eastern Arizona
4. realisticaly evaluate and consider shipping optionsprior to making offer please
5. no reasonable offer refused
6. Postal Money orders only
7. images e-mailed to your e-mail address
Michael
520-432-3011
mehalmorrison@hotmail.com
- Private 1st Class
Re: wc 52 drivetrain parts for sale
I'm asking $500 for every thing
michael wrote:origionaly this add was placed in the ww2 dodge forum
sheet metal
Michael
520-432-3011
