Today I spent a few hours making replacement handles for the new BC-348 radio. Originally I was going to cast them, but the plaster I use for mould making had gone off and wasn't setting properly.
Instead I decided to make them from flat sheet. I didn't have any sheet aluminium, so had to cut some strips from some channel section. This was then annealed, and the main arched folded around a shaped block. It was re-annealed and the end lugs folded over.
The holes were drilled next, then final shaping done with various files, followed by a light rub over with wet and dry paper.
Close up of one of the new handles fitted to the radio prior to painting.
