do you have a hood number? if not I think 2112649 might work for you.Olli P. wrote:I own a 1942 WC51 - chassis: 81601621
- My garage: 1942 WC54 Project
1943 WC54 Donor - Location: Ventura, CA
Re: New 3/4 ton database
Sorry - I do only have the chassis-number. And now I know that my hood-number is...a little bit...wrong...divingrocks wrote:do you have a hood number? if not I think 2112649 might work for you.Olli P. wrote:I own a 1942 WC51 - chassis: 81601621
Thanks, Olli
well, if you change your hood number to 294841 you'd be alot closer...do you have a build card for your truck? I'm pretty sure your truck is in the 2110000 plus range and was built in mid-December 42
http://www.autogallery.org.ru/k/da/t214.jpg
- Private
*-/-Hi all, Have just purchased a WC52, serial number 81721724, and body number 4290-28728, Engine is a newer replacement(KEW 260cuinch) I think serial number D49216603C.I can not find any other record plates on the vehicle, T he glove box lid is missing due to a Right hand drive conversion mant years ago. Going by your records I believe this vehicle was built in Aug 1944. The last owner has had it in his family for over 40 years, And has kept it in good order, less some mods that over time I think I can fix. Could you confirm my guess on manufacture date. and give me an approx hood number, also at this date would it have USA before or after the number. Any Info would be very much valued. Thanks Harry d
Harry,
My guess on the date of manufacture would be the first week of Aug 42 and in order to calculate a hood number a build card will be required, as there are several small production runs with varying sets of numbers...21????? is all I can tell you for sure. My wild guess is somewhere in the 2177182 to 2179292 range.
- Private
Thanks Drivingrocks, I asume that you ment Aug44 and not Aug 42? Thanks again , Harry
yep, 44 instead of 42...got 42 on the brain it seems!
- My garage: 1942 Dodge WC 51, serial 81589714
Can someone give me a hand with deciphering my build card?
Currently I've got the following information:
Serial: 8158 9714
Model: WC-51
Date of delivery: unknown
Date of build (build card): October 5th, 1942
Cowl/body number (current): 4290-27314
Cowl/body number (build card): 28279
Engine model: T214
Engine type: E5534 (upper side of the engine block)
Engine number: 1071829-4 (lower side of engine block)
Engine number (build card): T214-52026
Hood number: 294176 (not known if correct)
I am not able to place the numbers from the left-side to the right reading "83301" "85293" and "41815". Also the Body Model seems to read "26", which I am not able to place to a known Body Model.
The build cards with adjusted Color/Tones & brightness levels in the original format:
http://downloads.ww2airsoft.eu/Dodge/Buildcard_1.JPG
http://downloads.ww2airsoft.eu/Dodge/Buildcard_2.JPG
http://downloads.ww2airsoft.eu/Dodge/Buildcard_3.JPG
Serial: 8158 9714
Model: WC-51
Engine model: T214
- Private
- My garage: Dodge WC51, BSA M33, BV 202 NF1, Willys Jeep, Zündapp KS750, Hanomag 13B, Hanomag 13B.
hi. I am new at this forum so please pardon me for stupid question.
Where on my WC51 can I find all this numbers? If somebody put into the forum a photo with arrows of where to look for the numbers it will be very helpful for me (and others I hope..).
Regards from Norway (the Dodge land..)
http://i72.photobucket.com/albums/i163/ ... C00254.jpg
My wc-55 have fram nr 81529604 The hood number i found was for a Wc-52: 2357740. Only number i found, nothing under. Only primer. I did not write down the other numbers, silly me. Guess i will need to look. Just hope i didnt cover it totaly in paint.
On the right side i found the word "BOOM" in 3 inch letters.
bubo75 if you wonder about anything you could call me. i think i know abit about the dodge after taking it apart this winter. And im norwegan to.
here is a link to my resturation
viewtopic.php?f=5&t=5796
JT
JT
1944 Willys MB
1937 Sunbeam bicycle
Hi Bubo75.
Welcome to the best forum on the planet. The frame number is stamped into the left hand side (drivers side) frame rail above and slightly to the rear of the leading front spring hanger bracket. The numbers are quite large about 10 mm or so. The body/cowl number is to the left of the regulator. Well it was on mine though the tag with it on was missing! The engine number is on the block on the left handside front above the dynamo.
Phil
Phil
'Spirit of USS Arizona'
Feb '42 Ford GPW 'Yella Boyd'
1944 Willys MB
Hi divingrocks.
My frame no is 81603707 WC51. I see that that 81630648 is on your list which is just 59 before mine. I think that one is in British Columbia? That is dated 12/21/42. I assume mine is on the same day. How many other preserved Dodges are that close?
My 1944 Leyland Hippo is one of only 10 believed to be still running out of over 1000 built. It's National Service registration was 70 RE 85. One of the others still running is 70 RE 83.
Keep up the good work.
Phil
Phil
[quote="_Arthur]". Also the Body Model seems to read "26", which I am not able to place to a known Body Model.
[/quote]
Arthur,
Your card actually reads "66" for the body which is the suffix of the 4266 code for the pick up body only that was used on the WC-51 and WC-52. Give me a few days and I'll write your card up and e-mail it to you along with the info you requested.
Kevin Clause
[/quote]
Arthur,
Kevin Clause
Hi
Here is info on 3
WC57 that was parted out, very rusty
81575379, T214-241032, Body 4219-8564, hood USA 20185355
WC53 Sr 81630331, dod 3-8-43 eng T214-98777
WC55/52 sr 81530842 T214-128050 hood USA 6017587
Ernie
Here is info on 3
Ernie
Ok, it looks like your chassis has a had both the motor and body replaced at some point._Arthur wrote:Can someone give me a hand with deciphering my build card?
Serial: 8158 9714
Model: WC-51
Engine model: T214
