- My garage: 1942 Willys MB (Script)...Chassis # MB132051..."CONNIE"
1943 Bantam T-3 Trailer..ACM #B50604.............."Tandem Conversion)
1944 Willys MB.................Chassis #MB 302306 - Location: Haverhill,Suffolk,UK
Re: 3/4 Ton Database of 405 known
ONWARDS to 450 then "Rocks"....
Regards
Lloyd
Regards
Lloyd
1942 Willys MB (Script).Chassis #MB 132051."CONNIE"
1942 Dodge WC-51.Chassis #81563573
1943 Bantam T-3 Trailer..ACM # B50604.(Tandem)
1944 Willys MB.Chassis #MB 302306."CAROLE"
Are you in that garage again.? its about time you came in!
- divingrocks
- My garage: 1942 WC54 Project
1943 WC54 Donor - Location: Ventura, CA
Give me the body tag and I'll try to figure it out. Norweggians were fond of early bodies on later chassis' however...mannyc wrote:i have a norwegian command car return. has a restamped frame, no hood number. only a body tag. any way to recover frame # through the body #?
- My garage: Niek
(Belgium)
Re: 3/4 Ton Database of 400 known
Hey rocks,divingrocks wrote:Thanks for screwing-up my nice ROUND number of 400!Dodge'40-'45 wrote:Hello
I'd like to add 4 new entries:
Dodge WC53 VIN: 8619022 Body Number: 4249-6780 Original Hood Number: USA 2089530 (seven pointed star carryal markings)
Dodge WC54 VIN:81646681 Body Number: 4239-14907
Dodge WC56 VIN:81542107 Body Number: 4219-16439
Dodge WC64 VIN:81765303 Body Number: 4250-1747
Thanks,
Niek And Eric
I have calculated/SWAGGED the following for you:
WC54 726180
WC56 W-20168888
WC64 743482
There is something wrong with the serial number for the 53, can you recheck?
Yep you are right, it's supposed to be 81619022
thanks,
Niek and Eric
Niek
'42 WC53; '41 WC43; '43 Canadian D15/T222 GS; '43 WC56;
'44 WC54; '41 panel; '39 D12; '40 VC3
'44 GPW
https://picasaweb.google.com/109776084297346207961
Belgium
'44 GPW
Belgium
- My garage: 1942/3 WC51 - undergoing 'gradual' restoration.....
Okay.... having just done a clear out of some of my book shelves I came across some print-outs from 2005 of a Dodge Database from the website 'Powerup.com.au'....
Having compared them with this 'master database' there are a number that aren't on your d'b.... so.... I have written them out below for possible inclusion???
81532830 WC55 6019888
81535987 WC51 252763
81567223 WC54 719045 (different reg. no to your d'base...)
81573216 WC56 20165182 (different reg. no to your d'base..)
81574902 WC53 20165295
81581009 WC53 USN-232537 (diff reg. no??)
81586366 WC56 USN-129561 delivered 8/Dec/42
81598668 WC51 287208
81620911 WC56 20179603
81620934 WC54 710156 (diff reg. no??)
81621397 WC53 209007
81622615 WC56 20179988
81622888 WC56 20180058 delivered Jan 43
81624990 WC54 718886 (diff reg. no??)
81630767 WC57 ??? delivered 9th Mar 43
81640940 WC52 2187117
81642411 WC52 ??? delivered 22nd Mar 43
81651639 WC52 ??? delivered 2nd July 43
81691251 WC56 20460672 1944
81698821 WC51 ??? delivered 20th Mar 1944
81699762 WC51 2235404 delivered 31st Dec 43?
So... that is a possible 16 extra to add to the list and perhaps 5 with info updates (or your info may be more recent??) Not a bad trawl??
Hope this helps....
Gareth
Hope this helps....
Gareth
- divingrocks
Newton wrote:Okay.... having just done a clear out of some of my book shelves I came across some print-outs from 2005 of a Dodge Database from the website 'Powerup.com.au'....
Hope this helps....
Gareth
Thanks Gareth,
AWESOME effort...I hereby nominate you to "trawl" all the 1-1/2 ton T223 WC62's and 63's out there...!!!
Re: 3/4 Ton Database of 422 known
no worries - it's amazing what you can find on a dusty shelf if you look hard enough and blow the layers of dust away!!!!
will keep looking....
Gareth
Gareth
Re: 3/4 Ton Database of 423 known
do you need 1-1/2 ton T223 WC62's and 63's numbers??
i have wc63 82,042,551 info to come!! wood bed top and bottom
and apparently we smashed through the 400 mark!!
okey-dokey..... not sure about the following as have found them on the web with chassis serial numbers I'm not familiar with - but then I'm not familiar with 62's & 63's either!!!
Here goes....
82003766 WC63 3329520 no date given
82023733 WC62 no reg given Oct 1944
82027781 WC63 3338658 27th Dec 1943
82030532 WC63 no reg given 13th Dec 1943
82034542 WC63 3342321 15th Mar 1944
82037931 WC63 3337155 17th Nov 1944
Again, these are from an .au website so not sure how old or how accurate??
Could be good to add though?
Gareth
Here goes....
Gareth
- divingrocks
I was hoping yoou would keep and maintain this list as a separate thread/topic and be the 1-1/2 ton guy, what do you say?Newton wrote:okey-dokey..... not sure about the following as have found them on the web with chassis serial numbers I'm not familiar with - but then I'm not familiar with 62's & 63's either!!!
Here goes....
Gareth
not to be too slopey shoulders about it, but.... I am not a wc62/63 owner and suggest this might be better managed by someone who has this particular interest......
Anyone out there able to take this database for 62/63's over???????
Don't mind continuing to help with the 51/52/53/54/55's, etc.....
Off to Normandy on Monday for 5 days with the family (not in the WC as it currently has no rear axle attached!!!!) - will see what I can find and report back!
Tootle-pip....
Tootle-pip....
take lots of photos,, we love them, and enjoy!!! i'm jealous...
- Richard
- Private 1st Class
hello,
Some other carryall in my list:
wc53 81543479 4249-1178 2072532*
wc53 81543880
wc53 81577332
wc53 81630543 4249-8890 209....
wc53 8160?223 2090817
Regards
wc53 81543880
wc53 81577332
Regards
Richard
1942 WC53
1942 WC53
- Blacktom
- My garage: Steyr 380k, Steyr 380TLF, Dodge WC52
Hello,
I own:
WC 52 Frame # 81734983 engine # T214 166295 ex Austrian Army
WC 51 Frame # 81716025 engine # T214 E21024 ex Austrian Army
and the Wreck of a
WC 52 Frame # 81743046 Hood # 2304319 S
greetings from Austria!
Tom
I own:
and the Wreck of a
Tom
- divingrocks
I have calcualted hood numbers for you:Blacktom wrote:Hello,
I own:
and the Wreck of a
Tom
51 2247660
52 2270080
Do you know the body tag numbers for these trucks as well?
Re: 3/4 Ton Database of 430 known
I have WC-51 frame number of 81560119. It was overhauled after the war and the body tag on the cowl does not match the build card I got from the Chrysler archives (I assume the cab was swapped). According to the build card, my original body number was 17557, the engine number was T214-31790, and it was built Aug. 7, 1942. The hood number is long gone.
Thanks,
Joe
1942 Dodge WC-51 (from Norway)
Other M-Series Vehicles
Joe
