GX
Posted: Fri Jun 26, 2009 3:20 pm
by RANGER
CCKW C is fifor rugged waIt was in the vacuum erator Pump Circuit, compar echanical operated of the Die Cast Carburetor.
A th a Die Cast Carburetor is easier to start, especially if the CCKW has set ks.
Re: WAY GO
Posted: Mon Aug 17, 2009 2:35 am
by Dr Deuce
There are two times when the vac drops and the cast iron carb gives a shot of gas:
1. When running and you want to accelerate and press down on the pedal AND
2. When you shut the engine off and it coasts to a stop.
I had an M151A2 I could not figure out why it started soooo hard and seemed to be flooded when hot till I looked into the carb when I shut it off....
Re: GX
Posted: Mon Aug 17, 2009 1:34 pm
by retro-roco
RANGER wrote:The Cast Iron CCKW Carburetor is fifor rugged waIt was in the vacuum erator Pump Circuit, compar echanical operated of the Die Cast Carburetor.
Huh??
Re: GX
Posted: Thu Aug 27, 2009 12:26 am
by Dr Deuce
With the mechanical acc pump, if there is fuel in the bowl, you can inject it into the engine by pumping the pedal a couple times prior to cranking the engine.
With the vac operated cast iron carb, you cannot 'pump' raw gas into the engine unless it is running and has vacuume.
