speedometer cable routing
NWMV
Post by NWMV »
Can someone post a pic or explain the correct routing of the speedometer cable for a 6th serise CCKW353A1
Re: speedometer cable routing
It is not done by series, series reference is a figment, all CCKWs after chassis 41189 will be installed as shown on page 289, Figure 140, you will also find instructions for same in same manual TM9-801 April 1944. Page 276. Look up Engine Removal/Installation, there are illustrations that show the cable. For the type and dimension of te bolts used to attach the Cable clamps, it will be found in the SNL in Section 2208.
The TM is a good guide and will have most all that is needed for replacement of bolt on components such as the Speedometer Cable. Remember, the TM is your friend. :wink:
NWMV
Post by NWMV »
Thanks Ranger the only reason I mentioned series is I wasn't sure if there would be a difference. I always consult the manual first and if not 100% sure ask for for help. As Ranger says now your manual! :)
I always believe in homework. There is a lot more in the TMs than you think. That is why they have illustrations.
