NICE CCKW FINDS
Posted: Sun Jun 07, 2009 2:45 pm
The following gems are guaranteed to give the proud CCKW owner bragging rights. These items are the "icing on the cake" for your CCKW
GM-2190551 FAN BELT/GMC OVAL LOGO these were available from GM Dealers thru the mid 80s
GM-2147636 SPRING BRAKE HOSE SUSPENSION
5" KING BEE MIRROR
GMC HOT WATER HEATER KIT- GI Issue
FLOOR PLUGS (BRAKE INSPECTION-CAB HOLD DOWN BOLTS)
DRIVER AND PASSENGER SAFETY STRAPS
RUBBER HOOD BUMPERS
NOS RUBBER FLOORMAT
NOS OEM FIREWALL PAD
AC RADIATOR CAP W/HANDLE
DELCO HORN DELCO HEADLAMP SWITCH
H-700 KEYED DELCO IGNITION SWITCH
H-700 KEYED GLOVE BOX LOCK
H-700 KEYED SWB SPARE TIRE LOCK (NOS)
WWII DELCO INSTRUMENT SET
NOS DIE CAST CHOKE/THROTTLE KNOBS
KING SEELEY GOVERNOR w/seal
EARLY 40AMP DELCO VOLTAGE REGULATOR with 2-Bolt Cover
WWII ISSUE GUIDE HEADLAMP BULBS(Wartime dull Reflector)
NOS GUIDE BOD HEADLAMP KIT ON RADIATOR GUARD
NOS DIE CAST CARBURETOR
NOS CUP TYPE GOVERNOR SEAL AND WIRE KIT (embossed "GM")
DELCO OEM COMPONENTS in THE ENGINE COMPARTMENT
ORIGINAL IGNITION COIL (White Porcelin tower)
NOS HARD RUBBER STEERING WHEEL
(Traded to Mark Norman for like new WOOD STEERING WHEEL)
WWII ISSUE BRIDGE CLASSIFICATION PLATE
NOS WOOD STEERING WHEEL
NOS DASH PAD
NOS GUIDE A2 REFLECTORS/W STIMSONITE 12 LENS
NOS CLOSED CAB RUBBER FLOOR MAT
ORIGINAL CARGO BODY SAFETY STRAP
WWII ISSUE SNATCH BLOCK ( manufactured by Budd)
WWII ISSUE PIONEER TOOL BRACKET
PIONEER TOOL STRAPS (Riveted to the Running Board Brackets)
CORRECT PATTERN WWII GAS CAN STRAP BUCKLES
TAILGATE CHAIN COVERS
TM10-460 Driver's Manual w/forms inclosed
WWII ISSUE 1" LEATHER STRAPS ON THE PIONEER TOOL RACK
NOS CLOSED CAB SEAT CUSHIONS
DOGTAGS from your old ARMY DAYS
This is the stuff that CCKW collectors should keep a watchful eye out for, it can stil be found with a little patience. Some of it may take years and your CCKW may pass the century mark in doing so.
5" KING BEE MIRROR
RUBBER HOOD BUMPERS
NOS RUBBER FLOORMAT
NOS DASH PAD
