CORRECT CC
CORRECT CC
Re
Re: CORRECT CCKW CARBURETOR MOUNTING
Remember, the GCap points to
Do not attempt to take your governor apart to see what is inside, the gasket for the side cover is not available
not be sufficient to trap the contaminates.
IIRC there are two different gaskets that have 2 different patterns to accommodate the carb/gov mating.
Ref: AM Nov 1942
Why buy a gasket? Get a roll of gasket material and use the old trick of making one. Just as good, maybe a little more time consuming, but that's how they did in the Army cira 1940's. Why spend $10+ for a gasket when you can get a whole roll of gasket material for $5 and make just about every gasket on the truck.
Oh wait, I forgot, we lesser CCKW owners are incapable of any type of maintenance on our trucks. DARN IT. I better take the water pump off the old 270 becuase that gasket I make will probably blow the truck up when need it the most.
Ref: AM Nov 1942
"The RH mirror also comes in handy to look back and see if that kid who ran across your path in a parade made it." -Ranger
The most important gasket used
