Jeep metal sheet?
WC 56
Jeep metal sheet?
Post by WC 56 »
Hi all,
someone told me, that this metal sheet was mounted on a Willys MB/Ford GPW, but I don`t know where; does anybody know, if it is a WWII-part and where on the truck it was installed? The oil-can is to appreciate the size.
Greetings, Stephan
Willys MB,Bj. '43
Willys MBT, Bj. '43
Converto dump trailer, Bj. '43
Weasel M29c, Bj. '45
The story of 2 Unimog and their 4x4 friends: http://www.allrad-oldtimer.com
A website for a legendary WWII-vehicle: http://www.studebaker-weasel.com
Re: Jeep metal sheet?
It is the Air Cleaner Splash guard, it is located on chassis adjacent to starter/Generator. MB/GPW, CJ-2A and CJ3A Jeeps and later M-Series Jeeps.
WC 56
Post by WC 56 »
Thank you Ranger, that helps :D are there any parts necessary to install ?
maybe, someone have a pic of a mounted Splash guard :?:
Greetings, Stephan
Willys MB,Bj. '43
Willys MBT, Bj. '43
The threaded bolt holes are already in the chassis, the bolts are 1/4" NC with a split lockwasher and flat washer.
The tear in the sheetmetal is from fatigue, and is quite common.
WC 56
Post by WC 56 »
Thanks, Ranger for your detailed information; in addition, a picture would help me, because I can`t find no threaded bolt holes in the composite body of my MB :?
No one, who has an mounted Splash guard in an MB / GPW?
Willys MB,Bj. '43
Willys MBT, Bj. '43
You are looking in the wrong place, it does not attach to the body.Holes are in the engine side of the Chassis just to the rear of the passenger side engine mount. All MB/GPW, CJ-2A, CJ-3A etc had the splash shield. GPW was slightly different in appearance. they are there patiently waiting for you.
WC 56
Post by WC 56 »
Today, I will looking one more time exacting :arrow: to be continued......
Willys MB,Bj. '43
Willys MBT, Bj. '43
Something tells me you are getting closer. :wink:
WC 56
Post by WC 56 »
Thanks for your great help, Ranger :D
As I looked the first time, I didn`t see the holes in the chassis, because the original bolts are still in the holes, with broken off heads :oops:
Now it`s clear, the little flap with the hole is screwed on the right engine-bracket :)
Greetings, Stephan
Willys MB,Bj. '43
Willys MBT, Bj. '43
I just knew you would find the holes. :wink:
And you may be lucky, f the holes are oil or grease soaked, the broken pieces may still turn. Ifthe engine were out of the way a Left Hand Drill bit that turns in reverse sometimes does the trick.
WC 56
Post by WC 56 »
:? I wish, it were so easy; I think, the windings are rusted over the years, because the motor and the frame is not oily. I will carefully warm up the bolt holes with an flame cutter, then it seems to be possible to turn the bolts out with an left hand drill bit; I hope it works, no, I know it works :wink:
Willys MB,Bj. '43
Willys MBT, Bj. '43
If you try to drill with the bolts too hot, it will ruin the temper of the drill, sopmetimes a left hand drill bit with the drill in reverse will result in the bolt turning with the drill. You may get lucky.
WC 56
Post by WC 56 »
I will tell you some news when I work at the truck, currently there is much snow and too salty roads to drive Willys to my garage; NO springtime in south germany :(
Willys MB,Bj. '43
Willys MBT, Bj. '43
WC 56
Post by WC 56 »
Hi Ranger,
I just will let you know the currently look from the splash shield; think, it looks nice at the MB :D
Thanks for your great help!! :thumbup:
Greetings, Stephan
Willys MB,Bj. '43
Willys MBT, Bj. '43
