Wheel Hub Studs
Don
Wheel Hub Studs
Post by Don »
I'm servicing the brakes on my 1942 WC21 (military half ton), and noticed two of the wheel mounting studs on one hub are bent.
Can I use a hammer to remove these without hurting anything, or do I need to have them pressed out?
Thanks.
Re: Wheel Hub Studs
It isn't a job I've done, but I believe you can just punch them back through and tap new ones in. It may be worth putting a tired wheel nut on first and trying to knock them straight, rather than changing them.
gyknot
My garage: '41 dodge wc-1
'45 IHC m5h6
Re: Wheel Hub Studs
Post by gyknot »
agreed, I'd try to straighten it too before replacing. They should drive out though without the need of a press.
Don
Re: Wheel Hub Studs
Post by Don »
Thanks for the advice. I'll give a try with a hammer.
Think I will replace them, though. It looks like the weight of the truck came down on them, and buggered the threads. I've got replacements ordered from VPW.
-Don
Re: Wheel Hub Studs
OK Don, sounds reasonable.
I'd leave them in place till you actually had the replacements though, just in case. :mrgreen:
Re: Wheel Hub Studs
I had a couple of bent ones too... easy to knock em out. But since three of my hubs had right hand threads I bought enough to make them all right hand. And I had enough extra rh lug nuts to go around. Good luck.
Don
Follow-up: Wheel Studs
Post by Don »
I drove them out with just medium blows from a 2 lb hammer. Once they were out, I could see how bent they were and the threads were buggered pretty bad. The new studs from VPW matched perfectly. They went back in with the hammer, then I put a spacer and nut on them to make sure they were in all the way. Everything went very easy.
