A-pillar surgery
A-pillar surgery
So what looked like a small rust spot turned out to be much bigger. You can see how the rust and scale was forcing the inner joint apart. I cut out the rotten metal and treated the remaining metal with a rust neutralizer. I used the cut out piece for a template to fab a patch out of 16 gauge.
In pic #4 you can see that the rusty inner piece is/was not connected to the right side of the pillar. The two pieces overlapped each other and were held together with the five spot welds. The replacement patch will only be a single piece of 16 gauge, but it will be fully welded down both sides.
June J
My garage: 1942 Dodge WC 53
1960 M38A1 Nekaf
Re: A-pillar surgery
Post by June J »
Nice going! Its a tricky area to work in.
Getting there:
June J
1960 M38A1 Nekaf
Post by June J »
Made somewhere easier with tig/mig and cutting discs :)
My TD20 was particularly affected in that area and it all came down to mice - and their residue. It is worth noting that anything that needs you to cut through here should be thoroughly cleaned, flushed, and disinfected first, then use gloves and a dust mask.
The upside is that the metal in these pillars is relatively thick, so it is possible to cut out, remove, and plate back in large sections without losing the shape. A spot weld cutter lets you remove and then refit the drip rail too if you have to.
Gordon is correct about the mice and spot weld cutter. I have a 1971 Dodge Challenger. When I bought it mice had been nesting in the wiper cowl area for years. Their urine had completely rotted out the firewall. I figured I could drill out the spot welds on the wiper cowl, sandblast the area, and weld in patches. But naturally it didn’t work out that way. The cowl had maybe thirty spot welds and I tried to be cheap and use Chinese spot weld cutters. They were advertised as M2 tool steel and were relatively inexpensive, but looked great. Each bit lasted for about six spot welds. When it became obvious I would have to remove the firewall itself I was looking at many more spot welds. I stepped up and got some American made bits, and what a difference it made. I only used one bit for the firewall, the roof, floor, deck filler, and trunk pans; must have been hundreds of spot welds easily.
If you want to see pics, here is a link to my photo album: https://ImageEvent.com/adamell/wiperparts
Btw, I get a kick out of pics 235 & 236.
It still needs a little work, and seam sealer before paint.
nice job! :thumbup:
