Transfer case bearing numbers
Posted: Wed Mar 06, 2019 3:53 am
Does anybody know the bearing numbers (cups & cones) for the single speed T/C? 3/4 Ton. There are six of them, all the same size...
Update: This is a one speed 1/2 ton t/c, although I found it had “3/4” stamped into the case. I pulled the cups & cones out. The cups were Timkin 14276, and the cones were 14124. When I looked these up on Timkin’s web site it showed the 14124 bearing with a different cup. The 14276 cup was paired with a 14125A bearing. The 14124 & 14125A have exactly the same dimensions, but the 14124 has a slightly higher load rating.
Bearing cups: 14276
Bearings:14124 or 14125A
Bearing cups: 14276
