Source for WC51 Odometer Numbers
G. Miskovsky
Post by G. Miskovsky »
All,
Anyone have a source for the stick on odometer numbers for a early long needle speedo.
I tried to use the COREL files you can find on a popular J**p site no joy!
thanks
AIRBORNE ALL THE WAY!
Gus
'42 WC-51, '43 Ben Hur
dashtp40
My garage: WC-3
Re: Source for WC51 Odometer Numbers
Post by dashtp40 »
Gus,
I used odometer numbers from DCMClassics for my WC-3, I don't know if those will work on your WC-51.
G. Miskovsky
Thanks Steve,
Checked them out. They look great but are black on white where I need white on black numbers.
appreciate the help.
Gus
retro-roco
Post by retro-roco »
Hi Gus,
(That was my nickname in high school). I created the odometer font that I think you're referring to from the G503 forums. Who made your speedometer? Is it a Stewart Warner, King Seeley or other??
If you need numbers that are different than those I created before then the first thing I would need are some good straight on photos of each digit 0 through 9 and an accurate measurement of the height of the one and eight, and the width of the eight.
A picture like this is what you're after...
from that I can trace the digits and create a new font file like this (mine on top, original on the bottom):
Once we have the characters, then we will need to figure out the length you need for the strips to go around each odometer wheel, which will dictate the character spacing.
Kirk Gustafson
Item Coy, 23 Regt, 2 Inf Div
WWII HRS
G. Miskovsky
Kirk,
Looks like I may have the same font...what think you?
thanks for the help
Gus
retro-roco
I would say it is close. I would probably make some changes to the three, five and perhaps the seven. Who manufactured your speedometer?? Look like your wheels have spacers between. will need to know the precise width of the wheel, and the circumference. Pick a number on the wheel, and wrap a piece of paper aroun the wheel and mark off the circumference. You'll also need a "landmark" on the wheel, so you know how to position the new strips. I don't see any visible seams where the strips wrap around the wheels. What numbers are they located between??
Kirk Gustafson
WWII HRS
G. Miskovsky
Kirk,
My Speedo was made by Moto-Meter. The circumference is 2.38 in. Width is .210 in. Can't find a seam, been using a loop....no joy.
Gus
retro-roco
Here is a sample...Image
Kirk Gustafson
WWII HRS
G. Miskovsky
That looks great! What do you print your numbers on? Vinyl? or decal material?
Gus
retro-roco
All I've done in this venture is provide the custom font and artwork for the odometer rolls. Here is a link that describes how some of used them to restore their speedometers.
http://www.avi-plus.com/repair-tips-for ... .html#2421
https://www.befr.ebay.be/itm/Water-Slid ... :rk:2:pf:0
https://forums.g503.com/viewtopic.php?f ... t=odometer
Kirk Gustafson
WWII HRS
G. Miskovsky
Thanks Kirk, nice work!
Gus
dashtp40
My garage: WC-3
Post by dashtp40 »
I wish this information would have been available when I worked on my WC-3 speedometer. Now I want to remove it and work it over again! Excellent post!
retro-roco
Finished?? strips
Here is a link to a pdf file of the completed strips. https://www.dropbox.com/sh/hi5lop54hwal ... strips.pdf
Click download in the upper right corner. Let me know if you need the original Corel Draw file.
Kirk Gustafson
WWII HRS
G. Miskovsky
Kirk,
those are awesome! thanks! Is it possible to get a black numbers on white? is that something I can do with the download?
Gus
retro-roco
Kirk Gustafson
WWII HRS
