Brass bush
Posted: Mon Sep 17, 2018 1:04 pm
by egdod
Hi, does anyone know the size/thread etc of the brass bush that screws into the sloped master cylinder on a WC62 that accepts the brake line...
Thanks Dave
Re: Brass bush
Posted: Tue Sep 18, 2018 7:02 am
by motto
The connector is 3/8 NPT (18 TPI) on the outside for half it's length and is 11/16" hexagonal for the rest. It is internally threaded to take a 5/16" flared tube fitting/nipple.
Re: Brass bush
Posted: Tue Sep 18, 2018 6:44 pm
by egdod
Thanks a lot......could do with finding one!!!
Re: Brass bush
Posted: Tue Sep 18, 2018 8:41 pm
by motto
Vintage Power Wagons list that part as :- Brake Master Cylinder Outlet Nipple (ORD # 7351252) Part # 12:391441
Surely one of the European dealers would be able to supply one of these even if a takeout.
Re: Brass bush
Posted: Wed Sep 19, 2018 7:30 pm
by egdod
Hi, never seen it listed....
Re: Brass bush
Posted: Wed Sep 19, 2018 7:51 pm
by wc63-1944
Re: Brass bush
Posted: Thu Sep 20, 2018 11:33 am
by egdod
Hi Chris, thanks for that....think that looks like brass as per original!! Even better!
Re: Brass bush
Posted: Thu Sep 20, 2018 9:21 pm
by beepbeep
Jeepest has them also
https://jeepest.com/gb/brakeshand-brake ... &results=1 I've used both companies in the past and will now only use Jeep-Dodge-GMC if Jeepest don't have the parts I need. Hope this helps
Chris
Re: Brass bush
Posted: Fri Sep 21, 2018 9:29 am
by egdod
Thanks a lot.
