Water pump bolts/studs
Posted: Sun Apr 01, 2018 4:52 pm
by PareosWC
Gents, I'm applying a new water pump to my 230 motor, installed into the WC52. My WC manual shows (3) studs utilized. May I ask what length bolts you used in your block, and where did you place them? Looking at the front of the motor, I plan on using a stud at the 3 o'clock position, but which lengths to use at the 9 and 6?
Thanks! Got a good price on a Gates, then learned it was Chinese...
Re: Water pump bolts/studs
Posted: Tue Apr 03, 2018 5:58 pm
by jim lee
You may want to use bolts? There is not a lot of room between the pump and radiator when everything is together. If you need to pull the pump, studs may be an issue. Also, there is at least two different pump castings that have at least one mounting hole longer than the other. I'd take the pump you plan on using and match up a set of bolts that will fit.
-jim lee
Posted: Wed Apr 04, 2018 11:31 am
by PareosWC
Jim, I did not even think about the stud hindrance when removing the water pump
I plan on running the motor a good bit before assembling all of the sheet metal,
just to ensure we're free of leaks..
Posted: Sun Apr 15, 2018 3:42 pm
WC 3/4 tons used studs on the water pump and the cylinder head from the factory. later dodge trucks used bolts. studs are more reliable than bolts but it does mean you have to move the radiator farther out of the way to pull pump
Posted: Sun Apr 15, 2018 8:01 pm
by PareosWC
Kaegi, I ended up using new bolts at the 9 and 6 positions, but kept a stud at the 3 position where the genny brace is..
Posted: Mon Apr 16, 2018 12:43 am
bolts do make life easier. same with the head. studs on the head look cool tho. ;/)
