Dear friends,
I'm working on the WC-57 Command Car starter plunger.
It is bolted to the firewall, but I would like to know if there is or there is not one plate at the engine area to reinforce the plunger at the firewall from behind.
Pics is very welcome!
Randal
WC57 STARTER PLUNGER QUESTION
- Private 1st Class
- My garage: 1943 Dodge WC-57 Command Car
1943 GMC CCKW 352 Open Cab
1945 Ford GPW
1963 Willys M38A1C
Re: WC57 STARTER PLUNGER QUESTION
Nope. Just the plate bolted to the firewall- it is more of a mounted bushing: The starter rod passes through it, and connects to the starter lever. As you are not pushing on the mounted bushing at all(beyond return spring pressure) there is no need for any bracing...
As most Dodge owners know, once the plunger hole gets worn the rod can jam and this does put pressure on the light metal firewall (I had one crack.) Either keep the hole lubricated or pull it out and rebuild the cast fitting.
PS I agree with your saying on socialism but it was Margaret Thatcher who said it, not Churchill.
Apparently, Churchill ran out of other people's quotes...Lang wrote:As most Dodge owners know, once the plunger hole gets worn the rod can jam and this does put pressure on the light metal firewall (I had one crack.) Either keep the hole lubricated or pull it out and rebuild the cast fitting.
![Wink ;)](./images/smilies/icon_wink.gif)
