Here is something I have never come across before. I had an origional winch bumper in the blast cabinet and founld what looks like a stamping error. At first I thought someone had repunched a left to make a right bumper but there were no punches on the other side . It looks like it wase put into the press wrong and punched and later repaired with the pinchouts being swedged back into the wrong holes. I had never seen this mistake before but you know it had to happen sometimes. Go to;
http://winchbumper.MyPicGallery.com
Stamping Plant Error ????????
1943 WC-54 81635383
1943 GPW 146954
1945 WC52 818682 "MO"
1943 WC63 82009972 "BIG MO"
Interesting...
A different time then... they would actually take time to fix things rather than just scrapping the entire assembly.
I found this pach panel on a Carryall I restored a few years ago. The seams were lead filled and it was all under original primer and OD paint... done at the factory it would appear.
Real craftsmanship.
Real craftsmanship.
Carryall = not a patch
It was on the right side where the spare wheel well was on the half tons.
I think all the WC53's had that panel leaded in Chris, presumably on the body line and not even at the assembly plant..
Re: Carryall = not a patch
The patch in the photo above was on the driver's side, between the two rear windows. I thought the spare on the 1/2 tons was on the passenger side and a located a bit lower down... where the battery box is on the 3/4 tons?Gordon_M wrote:It was on the right side where the spare wheel well was on the half tons.
