For Sale: Repro data plates for WC-55 pedestal mounted 37mm
Posted: Mon Jan 01, 2007 1:36 am
Reproduction M25 and M26 cast brass data plates for the gun mounts in WC-55 Dodge gun carriages. The M25 plates are for gun mounts based on the M4 towed carriage with the palm button method of firing. The M26 plates are appropriate to pedestal mounts using parts of the M4A1 field carriage with the firing hand lever. If you are converting a towed 37mm for use in a WC-55, you will need one of these plates. $45 each plus $5 for postage.
