Electronic Ignition
G. Miskovsky
My garage: 1942 WC-51, 1943 Ben Hur
Electronic Ignition
Post by G. Miskovsky »
Greetings all,
Looking to replace my points and coil with a Pertronix or other brand electronic ignition.
Trying to figure out which part #. I searched the forum got some info but still puzzled.
My distributor:
- negative ground 6 volt AutoLight IGC 4703-1 (1943).
Any help?
thanks all
AIRBORNE ALL THE WAY!
Gus
'42 WC-51, '43 Ben Hur
Re: Electronic Ignition
Not something I've done Gus, but I know it does help, particularly with 6v systems. Power Wagon Forum if no-one here helps. Gordon
G. Miskovsky
Thanks Gordon
Gus
https://cdn.shopify.com/s/files/1/0247/ ... 1608310495
This Pertronix catalog should have what you need; also under footnote 55 it says you can get 6V negative ground by adding “6N” to the part number.
Tech support line
909-599-5955
Apparently the difference is in the dist cap size. 3-1/8 or 3-3/8. Vintage Power Wagons has electronic ignition modules for both sizes.
beepbeep
My garage: 1944 WC51
Post by beepbeep »
I’ve had a Pertronix on my WC51 for 10 years. They appear to have changed the part numbers since then but I’m pretty sure it’s a 2563LSN6, double check that though.
Chris
1944 WC51
zepher11
Post by zepher11 »
I've been running the Pertronix 6 volt ignitor in my 6 volt Dodge WC52 for many years. I just converted it to 12 volt. I had to change the ignitor to the 12 volt version a couple of weeks ago.
The 6 volt ignitor is: Pertronix 1567AN6. I called and they said to replace with 12 volt ignitor: Pertronix 1567A. They also said to just use a standard coil that I had lying around which I did. Starts right up and runs great after the conversion. 6 volt finally made me surrender after years of trying to hang in there with it. Hopefully, it'll keep starting for me vs. the 6 volt leaving me hanging after every parade, car show and so forth. I don't think I can add any more ground straps to it to try to make it somewhat reliable.
New genny and electronic regulator to go with as well. Plus a real battery holder set up on its way too:
Good luck with the conversion to the Pertronix!
Zeph
beepbeep
Post by beepbeep »
zepher11 wrote: Wed Aug 18, 2021 2:07 am I've been running the Pertronix 6 volt ignitor in my 6 volt Dodge WC52 for many years. I just converted it to 12 volt. I had to change the ignitor to the 12 volt version a couple of weeks ago.
That’s the part number on mine but for some reason it’s not listed in their catalogue, a search of their website found it listed in the shop though!
1944 WC51
G. Miskovsky
Did you have to change out the plug wires to copper core?
Gus
zepher11
Post by zepher11 »
G. Miskovsky wrote: Wed Aug 18, 2021 2:20 pm Did you have to change out the plug wires to copper core?
You know, it was about seven or eight years ago. I don't recall what plug wires are on there now. I remember one has to switch to the fiberglass core or to the metal core wires. I don't recall which. I'll have to look it up now to see what they recommend.
Zeph
