Oil filter
Oil filter
Does anyone have the NAPA number for a Dodge 230 C.I.D. oil filter?
Re: Oil filter
From the Power Wagon pif:
Canister, Napa 1080
Sock type 1011
Canister, Napa 1080
Sock type 1011
Re: Oil filter
for a WC 3/4 ton its the military standard Jr. if you tell napa to enter that it should come up. the PW uses a didfferent set up
Re: Oil filter
Military Standard Junior is correct. The '42 Jeep used the same filter so they are readily available.
Re: Oil filter
Good to know. Sorry for the bad info.
Re: Oil filter
this has every cross reference number needed! some of the numbers will have been updated but will get you the filter you need. it was widely used by most for decades. Baldwin P53 is a quality option
