Hi, does anyone know the size/thread etc of the brass bush that screws into the sloped master cylinder on a WC62 that accepts the brake line...
Thanks Dave
Brass bush
Re: Brass bush
The connector is 3/8 NPT (18 TPI) on the outside for half it's length and is 11/16" hexagonal for the rest. It is internally threaded to take a 5/16" flared tube fitting/nipple.
Re: Brass bush
Thanks a lot......could do with finding one!!!
Re: Brass bush
Vintage Power Wagons list that part as :- Brake Master Cylinder Outlet Nipple (ORD # 7351252) Part # 12:391441
Surely one of the European dealers would be able to supply one of these even if a takeout.
Re: Brass bush
Hi, never seen it listed....
- My garage: 1944 WC63 Dodge
1957 M201 Hotchkiss
1943 Jeep Trailer (under restoration)
1950's Pollynorm Jeep Trailer
Re: Brass bush
Hi Chris, thanks for that....think that looks like brass as per original!! Even better!
- My garage: 1944 WC51
Re: Brass bush
Jeepest has them also https://jeepest.com/gb/brakeshand-brake ... &results=1 I've used both companies in the past and will now only use Jeep-Dodge-GMC if Jeepest don't have the parts I need. Hope this helps
Chris
Chris
1944 WC51
Re: Brass bush
Thanks a lot.
