WC52 rear axle drain?
Anyone seen where a welded rear differential cover has been re-welded into a half moon shape? About half of the differential cover was welded back up...
- My garage: Restored Old Henry, and have had this WC51 on the road around 3 years now... Currently finishing a brace of Ben Hur trailers, and starting a 67 Galaxie fastback. Concurrent with the WC I restored a 74 TR6... Oh the joys.
Re: WC52 rear axle drain?
It sounds like that rear axle may have had some "work" done on it...
As to the "welded plug", it is not a plug- It is an adjuster for the side plat shoe on the ring gear: The nut is a jamb nut, welded to the central adjuster screw: Inside the case, it has a shoulder and pin: On the pin is a piece of flat metal, cut in a curve shape, and with a hole in the back for the pin. When the differential is assembled, the adjuster is tightened against the ring gear, then backed out a few thousandths- and then they weld it in place.
Scott
Scott
Socialism only works until you run out of other people's money. M. Thatcher...
10/42 WC-51 "Old Henry" (In Memory of Henry McBride)
11/73 (1974MY) Triumph TR6
01/91 Ford F-150 XLT Lariat XC/LB
2003 Ford P-71 exFHP
1967 Ford Galaxie 500 fastback
I agree sounds like rear was damaged and repaired. I have never seen one without a drain plug. you could just cut the weld all the way around and drill and tap for a bolt on cover but the bolt on covers for the big diff are hard to find.
G,Day all .I have a feeling that the lower stud on the front of the diff is the drain hole . It goes right thru the case into the oil . Remove stud and you should strike OIL . The same goes for the early diffs . Do not remove welded stud on side of diff . It is ,As Scott said an adjuster for the crown / ring gear . Ray
If I remember correctly, the late...welded cover type housing has a small 1/8" NPT plug at the very bottom. This is the drain plug. Just make sure that the oil is warm/hot before you try and drain it. As the small hole restricts the flow very much.
GPW 1944 (2), Studebaker US6 (2), Reo US6 (2)
never seen that before. I would grind the welds down
Yeah, somebody definitely did not want to replace that axle housing..never seen that before
Axle lobotomy scar
- My garage: 1942 Dodge WC 53
WOW, looks like that had a MAJOR ring gear failure, I'm glad I wasn't around to witness that one
maybe they broke an axle and too lazy to pull diff to get the piece out?
You think the previous owners name was Bubba
