Hi, I am looking for the brake pedal mounting bracket (2 of) that bolts to the chassis on a 3/4ton WC. Also, here in Australia most wc's have been converted to RH drive at some point in their past. To do this they cut (usually with an oxy) holes in the transmission cover for the clutch pedal.
This is not the part that can be un-bolted & taken out to get to the gearbox, but the piece that is spotted welded to the firewall. While they can be repaired, I was really hoping someone would have a couple of rusty cabs that they would be willing to cut these bits out of & send to me.
Thanks, any help will be much appreciated. Regards Bruce
Brake pedal mounting brackets wanted... & other parts
Re: Brake pedal mounting brackets wanted... & other parts
G,Day Bruce . Try Jay Allen or LLoyd Mc Carthy . Both in QLD or Keith Adam,s in NSW . As for brackets ,try MWM or VPW or maybe Ross Prince in Qld .What part of Australia are you in ? I Have a old truck from the Snowy hydro in my yard .But i think it is also RHD Converted .Ray In melbourne.
Cheers Ray, I have one bracket coming from VPW (that was all Steve has at the moment) but have not tried John at MWM yet. I will also give Ross a go. If you could check the cab you have that would be great. How would I contact LLoyd, Keith & Jay? I am in Jindera NSW...we have spoken a few times at Corowa. Regards Bruce
Bruce . Also try Benrie Brooks 02 6037 6234 . He is up your way some where. I cannot find my address book . Get back to you when i do . Ray .
- My garage: Restored Old Henry, and have had this WC51 on the road around 3 years now... Currently finishing a brace of Ben Hur trailers, and starting a 67 Galaxie fastback. Concurrent with the WC I restored a 74 TR6... Oh the joys.
Bruce, if you still need one, I have a brake pedal bracket- the one that bolts to the frame available... It was "torch nicked" on the lower inside edge of the bracket, on the inboard end: the truck had a winch mounted, but it was a cobbled together rig, & they cut it so the winch drive shaft would clear... It could be restored, or left as-is if desired, with no adverse operation...
PM me if interested. I'm in NJ, USA
Scott
Scott
Socialism only works until you run out of other people's money. M. Thatcher...
10/42 WC-51 "Old Henry" (In Memory of Henry McBride)
11/73 (1974MY) Triumph TR6
01/91 Ford F-150 XLT Lariat XC/LB
2003 Ford P-71 exFHP
1967 Ford Galaxie 500 fastback
Thanks for the help. I now have the brake pedal to frame mounting bracket but am still in need of a firewall piece if anyone has one. Regards Bruce
