Build Card Thread ( Sticky )
- Florence
Re: Dodge Truck Build Card compilation
Hello Juan,
yes the body tag - small tag on the body, underneath the hood on open caps - shows the Body No.
Greetings
Sylvia
Greetings
Sylvia
WC58 - 4229/933 July 1942 - Commander George
http://www.command-car.com
Dedicated to Dodge Command Car and Dodge Ambulance of WW2
Dodge Build Card collection:
http://www.command-car.com/technik/tech ... cards.html
- Florence
Just an idea ...
Maybe we can make this thread sticky?
Of course I would gladly direct link all the cards here BUT as the forum software cuts the pictures at ca. 600 px the cards would be cut at the right hand side as they are 710 px wide. If I shrink them to 600 px they are too small to clearly read the data.
one example of the 710 px cut pictures:
Greetings
Sylvia
Greetings
Sylvia
- divingrocks
- Master Sergeant
- My garage: 1942 WC54 Project
1943 WC54 Donor - Location: Ventura, CA
Sylvia, I took the liberty of putting a link to your website on my already sticky database post. I'll add one directly to the build card portion and maybe this topic too. let me know what you think
- Florence
Hi Rocks,
thanks for the link to command-car.com!
Another link to the build cards would be nice, too
However I think a sticky extra post might be fine, too as I think not everybody knows that a build card can be ordered by everyone.
Kindest regards
Sylvia
Kindest regards
Sylvia
- divingrocks
- Master Sergeant
done!
- Florence
Re: Dodge Truck Build Card compilation (50 +)
Time for a celebration - more than 50 build cards.
Thanks a lot to Richard T. from France who sent me another 23 build cards!!!
Today, 9. May 2011 there are 57 build cards.
Sylvia
Sylvia
- divingrocks
- Master Sergeant
someone will correct me if I'm wrong, but I have some more body codes for your build card registry
4270 for 6x6 chassis (WC62 & 63)
4250 for KD Ambulance Chassis (WC64)
4286 for 37MM Gun Mount Chassis (WC55)
- Florence
Thank you.
Sure about the 70 and 50?
Where did you get information about?
There is one card (12 Sep 1944) showing Body model 96 which is send to me as WC 63
Any more info out there from WC64 and WC62/63 owners
Greetings
Sylvia
Already have the WC55 / 4286.someone will correct me if I'm wrong, but I have some more body codes for your build card registry
Greetings
Sylvia
- divingrocks
- Master Sergeant
Hi Sylvia...O yea of little faith!Florence wrote:Thank you.
Greetings
Sylvia
I forget who I got the 64 info from, but it can probably be found in my database post somewhere. Rgus has a build card for his 63 and the proper nomenclature for a 55 is "gun motor carriage" I think.
- Florence
I added the "gun motor carriage" and under reserve the 70 and 50
Body Model Numbers:
10 = Flat faced cowl
12 = Closed cab
13 = Panel Van (also first hand-converted VC6 Carryalls)
19 = Reconnaissance (Command Car)
29 = Radio Reconnaissance (Radio Command Car)
39 = Ambulance
49 = Carryall
56 = Closed cab (half ton)
62 = Closed cab
66 = Express body with transverse rear seats
76 = Express body with no rearseats
86 = Gun motor carriage
90 = Flat faced cowl with bucket seats
under reserve and still confirmable:
70 and/or 96 for 6x6 chassis (WC62 & 63) ?
50 for KD Ambulance Chassis (WC64) ?
Sylvia
Body Model Numbers:
12 = Closed cab
39 = Ambulance
49 = Carryall
62 = Closed cab
Sylvia
- Florence
Hello,
today I added 2 more Dodge build cards from
March and July 1943. Thanks to Roberto from Italy.
Greetings
Sylvia
Greetings
Sylvia
- Florence
Another two build cards added, Oct. 43 and Feb. 44 - makes 61 cards now
Re: Dodge Truck Build Card compilation (60 +)
Florence,
Here is a link to a copy of my "Build Card" for your database.
Apparently the file is to big to send thru the forum. I also tried to send it via PM to you but I don't think it went through.
1942 WC-54
http://www.vmscompany.com/1942_WC54_CARD.JPG
Greg
1942 WC-54
Greg
Last edited by Greg Alexander on Mon Aug 08, 2011 12:15 am, edited 1 time in total.
I hope you don't mind me hijacking your thread Sylvia.
I made this blank buildcard up a wee while ago.
I thought it would be cool to take to shows without compromising the 'original' photocopy.
print on card, fill it out, voila.
Brent.
WC56.
WC56.
- Florence
Thanks for the card Greg!
The blank buildcard is VERY nice! Thanks a lot for that Brent.
If you agree I would be happy to add it to the build card compilation, too?
Sylvia
Sylvia
