VC Engine Dating
VC Engine Dating
A while back I bought a proper T202 engine for my VC 3 that had been stripped from another VC 3.
Just got round to looking at the serials and codes.
Engine code is T202-4988
Block is 1-16-40
Head is 12-14
So, head cast 14th December 1939, block cast 16th January 1940, and yet it is nearly 5000 into VC engine production?
Thoughts ?
Ernie Baals
Staff Sergeant
Staff Sergeant
Re: VC Engine Dating
Post by Ernie Baals »
Hi Gordon
Either the engine had been replaced sometime in its military life,
Or Like Willys engines first in last out, last in first out, of where ever Dodge stored the engine.
Nice early motor though :D
Ernie
68427vette
Post by 68427vette »
post / add a link on the vc vf spread sheet page,, and track the numbers, there should be a pattern, that would develop,, like Mb jeeps,, there were never a matching jeep/motor combo,, but t there is a range,, that makes it correct,
GPW all were matching numbered motor/frame/tags,,
good luck on getting walley to dig threw his treasures :wink: :lol:
if the block is Engine code is T202-4988 Block is 1-16-40 were does it fall in you vc list,, or may fall,, with the head data,, you could see if the head was replaced,, i have a vc block out side,, i'll check(came with vc3 from craig Johnson)
Looking for a donor M38 w/ good motor, Scoutcars and Halftracks, VC's, VF401-406
68427vette
here's is what i got:
driverside block:
5 T-202 1018
105 on a slant over
4-30 633329-5
sideways under the motor stamp(t202 #) front of motor driver side i have the numbers, do you have these? 372 74
HEAD top:
9 11 (small)
the clock arm was on 1 am or pm??
and 1120803 7
HOW ARE YOU DATING THE BLOCK ON YOUR S TO BE:
Block is 1-16-40??? :?:
am i missing a number?? location of this number :shock: ?????
my head is 9-11 so sept 11 1939?
i'll get some pics!!!
interesting topic.... pushing the hobby as usual gordon!!! :wink:
Well the block has the date code under the distributor, date code for the head is normally in the middle somewhere, and I've since been reminded that the bellhousings are also dated on the left front face, visible under the throttle linkage.
All the dates I have for VC and VF stuff are January / August 1940. Unlike other engine codes, like the T214 series, the T202 and T203 codes were only used that year, so if you have day and month you don't have to guess the year. Presumably there are some equivalent / extra civilian T203 engines ( they made export versions too ... )
68427vette
1054 is under my distr,
i think i original posted 105
1-05-40(?)
68427vette
HERE IS A LINK TO ALL THE MOTOR(I THINK)
http://s867.photobucket.com/albums/ab23 ... 27/MOTORS/
LABELED 1 -4 SOME T202 203 207
I see 4-30 in that image, 30th April 1940 then ?
As I said above for T202 and T203 engine components they only ran from September '39 to August '40, with the majority of the production being Easter-August 1940, so you don't actually need the year to date them.
68427vette
#1 spare from craig jo vc3?
T-202 1018
date 4-30
april 30, 1940?
cast: 633329-5
#2 motor is from the Texas truck VC1
T202 3987
date M 15
http://i867.photobucket.com/albums/ab23 ... ORS023.jpg
date???
cast: 1119729-B
#3 motor, black VC3 from BOB Stopko
T202-4684
date 2-11
Feb 11, 1940??
cast: 633629-5
**YOUR MOTOR**
T202-4988
date 1-16
Jan 16, 1940
#4 motor VF
T203 5837
date 8-13
August 13 1940?
could these been made in 1939? for 1940 production? we need more info,, on DATA PLATED trucks with t202 motors in them!!! with DOD, info...
WALLEY????? :thumbup:
ernie may have something
"first in last out, last in first out"
ernie or jamie,, have any info???? vc1 ??
Ernie Baals
Staff Sergeant
Staff Sergeant
Hi
Here are the numbers from my 2
the first one is in a Fire Chief tractor
T202 10644
Under the dist
837
15
1119729-16
Second is
T202-4?34 over stamped with 7-2-4
on side of block
A
1-19-40
860129-14
Very different numbers on the block, i am confused as the stampings are very different
Here are some pictures
You do not have the required permissions to view the files attached to this post.
68427vette
gordon what do the books say as CASTING BLOCK NUMBER>??
1119729-16
or
860129-14
jc
civi vrs military?
YES,, no real pattern,, even with the dating castings???
I've never bothered to look at the casting numbers Jeff, I wouldn't think they were that significant, but not sure. The 'casting number' is usually just assigned to each engineering code, with a suffix indicating which pattern it was of the bunch. If your production quantity was relatively low there may only have been one or two patterns used for each engineering code, and some of those patterns would almost certainly have been the previous years patterns with slight repairs and alterations for the updated engine specifications.
VC / T202 and VF / T203 are quite interesting engineering codes.
As far as I know the T202 code was only used for the military 4 x 4 VC, so any engine with a T202 code came from a military VC half ton...
I know the T203 code was used for VF 4 x 4 production for the US Army, and at least one batch of VF production for export, which I think was run right at the end of US VF production. I seem to remember that they also ran some VF 4 x 2 trucks which may or may not have had a T203 code and could have been military, civilian, or both. It is a similar situation to the T110 engineering code which we all associate with the Canadian Dodge D60 3 ton 4 x 2 trucks, but was also used as a code for civilian 3 tons I think.
68427vette
these blocks have differansce all over them,, for being such a LOW production motor,, why would we see,
2 casting numbers
1119729-16
860129-14
also the dating on the blocks, under dist.. come in at least 3 forms.
example:
1.) 15
2.) 1-19-40- (full write out of year)(ernies)
and
3.) 8-13
versions......
interesting topic,,
68427vette
how would we date ernie motor:
T202 10644
Under the dist
837
15
1119729-16
if 15 is jan 5th?? his number T202- 10644, is way off..
unless the NUMBER T207-XXXXX, were stamped as they were put in!! and the casting date of 15, would just be a stock pile of motors, waiting to be installed.. then stamped T202-XXXX. So,, dating a block , has no meaning to the T202-XXX number.??????????
are we confident to say that 15, is JAN 5th, 1940?
MY vc1 texas truck has
my motor is from the Texas truck VC1
T202 3987
date M 15
ernie do you have an "M" also -just more questions...
is it also 15(date), or jan 15th 1940??? T202-3987(mine) (10644)ernie) have the same casting date, yet !!!! 6657 off (more that all the vc production, odd)
we need a spread sheet....????
68427vette
some more to add:
looking at ernie s motor:
the first one is in a Fire Chief tractorT202 10644
Under the dist
837
15
1119729-16
i wonder if this has anything to tell us? commercial none, truck use? casting number 1119729-16
thoughts?? i'll check my castings!!!
