Found CCKW
- My garage: 1941 Dodge WC-43 Telephone Installation (replica)
194? K-38 Telephone Tool Trailer
194? Ben Hur Trailer
1968 Kaiser Jeep M35A2 with winch - Location: Southern California
Found CCKW
Found not too far from my home. Am working on the owner to let it go.
You do not have the required permissions to view the files attached to this post.
Re: Found CCKW
More pics
Needs a little work
I think the VF may be a little easier, but I do see some good bits. Hopefully the carb didn't let a pile of c!"p get down there and wreck the engine
What's that big thing next to the carb then?
Re: Found CCKW
I was told that this truck belonged to school and they installed a 120 volt alternator to run power tools, so we guess that the large item mounted above the alternator is the battery-charging rectifier.
Re: Found CCKW
Don't give too much for it.
Re: Found CCKW
Looks to have DUKW wheels up front and regular wheels in the rear. Great way to blow the transfer case if the tire sizes aren't matched. Keep an eye open for that one.
--Nick
--Nick
Nick Bombini
'42 M7A1 Generator
'42 M7 Generator trailer
'43 CCKW 352 A2
'45 USMC mobile repair shop trailer
'45 GPW
'42 M7A1 Generator
'43 CCKW 352 A2
'45 GPW
Re: Found CCKW
The only part of the drive train which was obviously missing is the front drive shaft. Can't break the transfer case any time soon!! THANKS for the heads-up!
Re: Found CCKW
Maybe that is why the front shaft has been removed.
Re: Found CCKW
Good, they were smart when they did that then. I have seen people put different sized tires on 4x4 trucks and wonder why they break parts.Ken J wrote:The only part of the drive train which was obviously missing is the front drive shaft. Can't break the transfer case any time soon!! THANKS for the heads-up!
Does the data plate above the steering wheel call for 7.50x20 or 11.00x18 DUKW tires? If the DUKW tires are called for, it could be a different variant of the truck such as a bolster truck or a navy contract special purpose rig either of which could explain the data plate on the outside driver side cowl.
--Nick
Nick Bombini
'42 M7A1 Generator
'43 CCKW 352 A2
'45 GPW
'42 M7A1 Generator
'43 CCKW 352 A2
'45 GPW
Re: Found CCKW
Ooooh, didn't take a picture of that- didn't see it!
Re: Found CCKW
I still belierve the data plate on the side is removed from an M-211 and is just a patch over a hole.
Re: Found CCKW
NICK:
I looked carefully at the plate above the steering wheel (which you can see I did actually get an angled picture of) and it looks like 7.50-20 tires.
