LS-3 Speaker parts wanted
- 12th Air Force
- My garage: Dodge WC51 built 1942. Former 4x4 MV: Dodge WC52, LR 109 ex MOD FFR (fitted for radio) Series IIA and Series III, Series III Stage1 V8 with Ambulance Body (ex. MOD), Series II 88 ex. BGS (German Border Patrol).
Hello Folks,
I need a set of original screws that keep the LS-3 speaker front panel in place.
It is "something between M3 and M4" (sure: not metrical) and I have no source for those lousy screws...
In addition I need the original plug for the speaker!
- I thought the PL-54 would fit - but it seems that this type is to big (diameter to large)
Any idea what plug fit's to this speaker?
Recommendations for a source?
Thank's for any hint,
Joakim
Joakim
- My garage: 1944 WC51
Re: LS-3 Speaker parts wanted
Hi Joakim,
I think it may be the PL-68 plug you need, it's slightly smaller in diameter than the PL-54. Hard to get though, Fair radio in the US have used ones listed and here's one on EBay in the US http://www.ebay.co.uk/itm/PJ-068-mic-CO ... 0985313842 expensive though. Closer to home you might try here http://grc9.nl/webshop/index.php?_a=pro ... uct_id=133 the switch they sell looks in the photos to use a PL-68 but you would have to email them to confirm. Screws I don't know, sorry.
Chris.
Chris.
1944 WC51
Screws definitely NOT metric: Should be an 8-32 or 10-32, IIRC... And they would be a pan head, if memory serves. But NOT metric!
- 12th Air Force
ng19delta wrote:Screws definitely NOT metric: Should be an 8-32 or 10-32, IIRC... And they would be a pan head, if memory serves. But NOT metric!
Right - they are panhead ones, made of steel with black surface and about 10-15 mm long (sorry that I have no picture at hand).
Actually I have only 4 original ones to keep the front cover in place - so I'm looking for a source to get a set of new ones...
Any idea?
Joakim
- 12th Air Force
beepbeep wrote:Hi Joakim,
Chris.
Hi Chris,
thank's for the cool hint! I try to get one of this type - because the actual solution is simply to have the cord fiddled thru the socket and plugged it then directly into the speaker. Not the original solution - more "Russian style of improvisation".
Have a great evening downtown,
Joakim
Not sure what you have in Germany, but McMaster-Carr in the US would be my best suggestion-http://www.mcmaster.com/#machine-screws/=v9ns47
http://www.mcmaster.com/#93923a427/=v9nsy8
- 12th Air Force
ng19delta wrote:Not sure what you have in Germany, but McMaster-Carr in the US would be my best suggestion-http://www.mcmaster.com/#machine-screws/=v9ns47
Hi Scott,
that's a great source - esp. because round head screws went out of production over here years ago.
So I had a look at the link and found the correct design:
http://www.mcmaster.com/#machine-screws/=v9w7rr
But: what size will fit?
Have a good start into 2015,
Joakim
I'm thinking probably the 8-32 or 10-32: I would say the best way to figure it out is to check the size if you have a threaded receptacle hole the screw goes into, using a tap from an SAE tap set... If it is just a hole, go with what fits!12th Air Force wrote:ng19delta wrote:Not sure what you have in Germany, but McMaster-Carr in the US would be my best suggestion-http://www.mcmaster.com/#machine-screws/=v9ns47
Hi Scott,
Joakim
- 12th Air Force
Hi Scott,
I had nothing to check the correct diameter but actually it looks like that:
So you can see in every case the difference in size between the data-plate screws and the missing front panel screws (if that helps).
Joakim
I'd say to just pull one of those screws(pop rivets?) out & measure the hole then...
