Pintle Hook installation...help
Ernest Aguilar
Post by Ernest Aguilar »
We are trying to reinstall the pintle hook on our truck put can't figure how to get the brushing off ?? Pressed or are they threaded or just rusted on??
Ernie Aguilar
Las Vegas,NV
WC 27 81510000 11/41
45 MB 2/45
motto
Re: Pintle Hook installation...help
Post by motto »
I'm assuming that you have removed the large castleated nut.
One or both of the collars is rusted on Ernie. You could try using a bit of heat (Oxy/Acetylene) on the exposed ends but not near the spring. From memory only the ends of the collars are in contact with the shaft, about the first 1-1/4 inches or so. The rest of the bore is a larger diameter. The collars are supposed to be a sliding fit. With the nut removed the hook should just pull out.
