1.5 TON Database of 128 Known
rgus
My garage: 1942 CCKW 129,XXX
1943 WC-54 81635383
1943 GPW 146954
1945 WC52 818682 "MO"
1943 WC63 82009972 "BIG MO"
1944 CHECKER 1 TON TRAILER
Re: 1.5 TON Database of 91 known
Post by rgus »
Bump
divingrocks
My garage: 1942 WC54 Project
1943 WC54 Donor
Post by divingrocks »
found some data in an old post
wc62 82000913
wc62 82042020 t223-43582
wc63 82042577
wc63 82043098
wc63, USA 3330201 82006576
rgus
1943 WC-54 81635383
1943 GPW 146954
Re: 1.5 TON Database of 96 known
Post by rgus »
added....up to 96 Thanks Brian
divingrocks
1943 WC54 Donor
82003982 WC-63
currently on ebay
rgus
1943 WC-54 81635383
1943 GPW 146954
Re: 1.5 TON Database of 97 known
Post by rgus »
Added Thanks
divingrocks
1943 WC54 Donor
just dug up some more
82003699 62
82006211 63
82023135 62 10/16/43 T223-23071
82024555 62
82032799 63
82033524 62
82037962 63
82031633 63 3311849
your list also has two number out of sequence...8203532 and 82003766
Robin
Re: 1.5 TON Database of 105 known
Post by Robin »
82002701 WC-62 1943.
rgus
1943 WC-54 81635383
1943 GPW 146954
Re: 1.5 TON Database of 106 known
Post by rgus »
Brian those frame numbers are already in the database as for the other 2 8233532 is only 7 didgets so it is invalid and 82003766 is setting between 82003699 and 82003982. Hell I have to dig out the build card and add 62000299 which is my WC-63.
82002701 is addad ...thanks
achiem37
Post by achiem37 »
I just picked up a 1943 WC63 with a serial # of 82025440 . It's currently apart in my garage under restoration.. Terry
rgus
1943 WC-54 81635383
1943 GPW 146954
Re: 1.5 TON Database of 107 known
Post by rgus »
Terry Added to the list. Let me know if you find any other sata you want added
c.e.culverhouse
Post by c.e.culverhouse »
Just to add 82021566 WC63.
rgus
1943 WC-54 81635383
1943 GPW 146954
Re: 1.5 TON Database of 108 known
Post by rgus »
Added thanks
patclarkbarnes
Private
Post by patclarkbarnes »
Hey I picked up a 45 WC 63 82009008
rgus
1943 WC-54 81635383
1943 GPW 146954
Re: 1.5 TON Database of 109 known
Post by rgus »
Added thanks.
Number makes it an early WC, made in 1943. It should have all the early features. all steel bed, short runningboards, high seats etc.
divingrocks
1943 WC54 Donor
motto wrote:The frame number on my WC63 is a puzzle to me. I've looked very closely and there appears to be a gap between the first and second (third?) digits with nothing discernible in that area at all.
The number is as follows:- 8 027687
I purchased the truck in the UK many years ago and have no knowledge of its prior history. The cargo body did not match the truck as it is the late timber composite with the short L/H box while the truck had the short running board under the spare wheel. The engine had no number at all and has now been replaced with a T223 sourced locally as it had a knock in it anyway. There was a number on the bonnet but I don't imagine it is relevant to anything as everything seems to have been messed with during an attempted restoration.
Any idea what digit is missing from the frame number? I assume there should be no gap.
