My '44 Flying Control Dodge
armyairforce
My garage: 'Follow Me' Jeep
Dodge WC51
'Station Photo' Jeep
Roset Trailer
B-17G Fortress #42-31035
Post by armyairforce »
With the winch in place, I wanted to check its position in relation to the child seat. I'd removed it to make more space in the truck, but lifted it back out from under the truck for a temporary fit check. It's heavy and awkward to move, especially was there wasn't much room at the back of the Dodge to get passed, but it was necessary. There was enough space for my daughter to climb in passed the winch and it also allowed me to check the winch cable would clear the seat. The winch cable will normally be fully wound onto the drum when not being used, so she won't have to climb over the cable to get in.
From the rear, the cable just clears the seat as it passes down the centreline of the truck towards the A-Frame.
The last picture has the cable stretched out, about to drag a tent off the storage shelf! That was simply used to hold the cable out straight for pictures and to stop the cable from unwinding from the drum. All that's left on the base frame are the hinge points for the A-Frame.
I need to turn the Dodge around in the garage so the tailgate is at the garage door end. I'll then be able to open the garage door and jig up the A-Frame bars sticking out of the door to work out the hinge angles and to trim the mating faces of the bars where the chain hoist mounting plates will attach. Cutting and drilling the A-Frame hinge plates and the chain hoist plates will be the next job before the A-Frame can be assembled. That's all there is to do, other than priming and painting all the metalwork.
Steve Carr
armyairforce
Dodge WC51
Roset Trailer
December 14th - A-Frame Head and Hoist
On Tuesday afternoon, I started the A-Frame head, the flat plates that both the winch cable and chain hoist attach to on the end of the round bars. A 1/1 scale drawing was made first to check how the hoist would hang in relation to the hole, plate and bar at various angles. The angles and hole centres were marked up with tape next, then drilled for a joining bolt. This will be used for holding the two sections of the A-Frame together when complete. Another bolt hole was drilled in an area that will be cut off. This bolt is just to hold the two plates together while being cut and shaped. With the two bits bolted firmly together, centre holes were drilled for the winch cable attachment and chain hoist hook.
Since I don't have a 20mm and 40mm drill bit, or a pillar drill big enough to handle them, the large holes would be opened up by chain drilling. Wooden templates were epoxied over the centre holes as a guide for the chain drilling. They would also help to hold cooling oil in the area while drilling. It took some time with a 4mm bit to chain drill both holes, after which the plates were separated and the webs between the holes broken through to release the waste from the centre of the holes. Both parts were washed of swarf and oil and then put in my curing cabinet to fully dry. They need bolting back together before the round and half round files come out to clean up the holes.
Steve Carr
armyairforce
Dodge WC51
Roset Trailer
I wanted to join the winch hook to the A-Frame head via a 'U' shackle. However, the shackle was to thick to clear the safety jaw on the hook. I didn't want to reduce the diameter of the shackle, so modifying the hook as the only option. The end of the spring loaded jaw was cut off, allowing it to open back away from the hook. This of course meant it would no longer stay closed, but it would open outwards to let the shackle into the hook. A new tip was added to the safety jaw, pivoting on a small bolt. The end of this tip was formed into a 'V' shape so that it would seat into the inside shape of the hook with the original spring keeping pressure on it which held it in place.
The chain hoist was partially dismantled this afternoon and both the case and hook given a coat of olive drab. The main hoist needs to dry before turning and the other side painting.
Steve Carr
armyairforce
Dodge WC51
Roset Trailer
December 15th - A-Frame Head
It was a hard day of elbow grease on the 15th. With the holes rough cut the day before, it was time to get the files out to clean up the edges of the holes. The larger hole took most of the morning using a combination of a half round file to take most of the material off and a power file to finish.
The smaller hole was too small for my half round file, so I started off with a smaller round file. Again, it was slow progress until I spotted a conical grinding wheel in the bits box next to my lathe. This was fitted to my pillar drill and was spot on for the hole size I wanted. It took around an hour, working from each side of the combined 1/2 inch thick steel plates. I found it worked better with a little oil to both lubricate the stone to stop it jamming and to create a cutting paste from the debris it was removing.
Steve Carr
armyairforce
Dodge WC51
Roset Trailer
With both holes cut, it was time to start trimming the plates. I don't have any huge metal shears and with 1/2 inch of steel to cut through, the angle grinder was the only option I had. The top angle and rounding off by the shackle hole was cut first. The bottom corner was still being used to bolt the two plates together. The 1/2 inch thick steel put up a good fight, but eventually, the top was cut free. All the other corners were rounded off next and lastly the bottom angle.
I cut from both ends, all the way through, leaving a small section in the middle holding everything together and aligned until the last minute when the corner was finally broken free.
Steve Carr
armyairforce
Dodge WC51
Roset Trailer
The plates were then separated and the edges all cleaned up with the belt sander and a small file to make sure there were no sharp edges or swarf remaining. The picture below shows the plates with the A-Frame bar positioned on top. The bar needs a tapered cut for the plate to mount on to, but I need to jig it all up in the back of the truck to get the angles correct. I had thought about turning the truck around today, but had nobody to help guide me out of the narrow door, so I'll probably do that tomorrow.
The only other jobs done today was giving the hoist and winch another coat of olive drab. The winch and hoist cover plate were left in the curing cabinet while the hoist was hung over a heater.
Steve Carr
armyairforce
Dodge WC51
Roset Trailer
December 16th - Crane Build Preparation
The Dodge was turned around on the 16th, allowing easy access to the back of the truck and more space with the garage door open. With the truck tail in, there was no room to lay out the crane parts.
While I was out there, I balanced the bars on a stool, along with the crane head, to get a feel for the scale of the crane. Longer would have looked better, but I needed to compromise on the length so the bars could be transported inside the Dodge more easily. In the future, I could look for a larger diameter bar that would slot over the originals to create an extension, but that wasn't really important for now. The bars for the A-Frame are two metres long, plus a little extra for the hinge and crane head.
Steve Carr
armyairforce
Dodge WC51
Roset Trailer
Inside looking out. With the crane out flat like this, the winch wire would be at a very shallow angle and probably wouldn't lift it. I'm contemplating putting a stop in to prevent the crane from lowering too far.
Lifting one of the bars up, I tried to get an idea of the angle and height if the crane was lifted high enough for the tailgate to close. At events like Beamish where we can drive around, I'd like to be able to do it without dismantling the crane.
Steve Carr
armyairforce
Dodge WC51
Roset Trailer
December 17th - Crane Construction
I began the 17th in the workshop, drilling the hinge plates for the bars and floor frame. The bars were then taken onto the patio and one end slotted for the hinge plate with an angle grinder.
Out to the garage next and the hinge mounts were jigged up on the floor frame using some studding to hold the position and spacing. They were then given a few small tack welds to hold them in place in case I needed to make any changes.
Steve Carr
armyairforce
Dodge WC51
Roset Trailer
After a quick check that the hinge plates were clear of the bolt holding the floor frame to the floor, the hinge plates were welded into the A-Frame bars. This allowed them to be temporarily mounted to the hinge mounts with some studding.
With the bars fitted in the truck bed, the top ends were pulled together to work out the taper angle that they would need to be cut to, in order to fit the frame head. The cut lines were marked with masking tape.
Steve Carr
armyairforce
Dodge WC51
Roset Trailer
More noise and sparks from the angle grinder got them cut, followed by more noise as the faces were fine tuned to fit together with the crane head between them.
With that done, the crane head was jigged up between the two bars, using some G-clamps to set the height and some copper wire wrapped around the bars to hold them against the face of the crane head.
Steve Carr
armyairforce
Dodge WC51
Roset Trailer
After a few tack welds, the A-Frame was lifted and propped up on a piece of wood to see how it looked. I was rather pleased with myself and the way it was coming together.
It then occured to me there was nothing stopping me from rigging it up properly, so I went to the workshop and brought the winch and chain hoist back out. The winch was bolted in place and the cable strung to the A-Frame. It was winched up and the chain hoist hooked in place for some pictures. I was really liking the look of it now. It should be great on the show circuit next year.
Steve Carr
armyairforce
Dodge WC51
Roset Trailer
It was after 1pm and I was feeling hungry. I didn't want to leave it hanging unattended while I was still working on it, so lifted the A-Frame a bit higher, allowing me to close the tailgate to help support the crane while I was away. With the chain hook attached to the Dodge tow hook, I could probably drive around an event quite safely like this. I plan to weld some small hooks to the bars so the hoisting chain can be wrapped over them and secured. I think it is better dismantled for on the road travelling to events.
Back from lunch and I welded up the hinge mounts fully and also the crane head. I used the tips from the tube offcuts to cap the ends of the tubes against the crane head to keep water out if it rains. When I bought the Dodge, it also had some shackles, plus a hook and pulley in one of the lockers. They were probably accessories from a WC52. So the crane was lowered and re-rigged with the hook and pulley at the top end of the crane, looping the winch wire back to the winch. This rigging halves the load on the winch and I think makes it look more interesting.
Steve Carr
armyairforce
Dodge WC51
Roset Trailer
Below is a closer view of the crane head and pulley. I like this system better, but would like to make some form of guard on the hook to prevent it from accidentally unhooking. Once complete, I'll need to start testing it under various loads to see what it can manage. For now, I know it will support at least 14 stone - me with my warm clothing and work boots on!
By late afternoon, it was getting pretty cold outside, so I de-rigged the crane and packed up for the day.
Steve Carr
armyairforce
Dodge WC51
Roset Trailer
December 18th - Crane Construction
Final fettling work today. Another hole was drilled in the crane head for a second bolt to hold the two plates together. The welding distorted them slightly, so the additional bolt in the lower half helps to keep them together. Three hooks were welded to the right side A-Frame bar next. If I want to drive, I need to stop everything swinging around.
The hoist lifting hook is a good fit in the Dodge tow hook, so that can be fastened in there and the slack taken up against the pull of the winch cables. The hoist chains can then be wrapped around the A-Frame bars and over the hooks, keeping them out of the way.
Steve Carr
