carryall
Private 1st Class
Private 1st Class
Re: 3/4 Ton Database
Post by carryall »
Hi all,some news from Norway again.
On my Wc 57 I have discovered the hood number in 2" lettering it is like this:
81673639 WC57 20294925
And body# 4219/20815
My friend has the following numbers (also undiscovered hood number)
81673594 WC57 20295085
And body# 4219/20811
Strange thing is that his car is earlier in all numbers, but not on the registration number?
Regards from Norway.
Raymond.
divingrocks
My garage: 1942 WC54 Project
1943 WC54 Donor
Post by divingrocks »
Hi,
I have added your actual hood numbers to the database...the calculated ones I had previously listed were both about 3000 off...glad you found your original numbers!
Route1
Private
Post by Route1 »
Wc51 81500454
divingrocks
1943 WC54 Donor
Route1 wrote:Wc51 81500454
I don't think you have a 3/4 ton....got a pic of it?
ng19delta
Post by ng19delta »
divingrocks wrote:If all the numbers you gave me are correct and your chassis has no factory winch...you probably have a WC51 made in early October 1942
ng19delta wrote:Hi- I am still working on my WC's identity, but the serial number is 81589786(from frame rail- the 8 & 1 are covered by an added piece to be removed) and the USA number appears to be W-277559: I have not completed sanding back to it. I started today, but due to a lighting issue, sanded through part before I saw the dark blue markings! ARRRGGGHHH! It is a WC-51. The cab number is 4290-28313, and the original engine number is unknown: It currently has a P-23 engine in it! :p I'll be doing more sanding, more carefully, tomorrow- and with better light!
I just rescued this one from a scrapyard in Arizona, and had it dragged(on a U-haul car carrier) all the way across the USA to New Jersey. Can't wait to get into the meat of this restoration!
Hi- I know the chassis number is correct, and the cab number is correct, my only question is still the hood number... (By correct, I mean that is what's stamped there... God only knows if the cab was swapped at some point!) I tried estimating date based on the build cards elsewhere on the site, and bracketing the serial number and extrapolating, but my estimate came out around the first week of January. I am most likely wrong(especially since the body tag says 42) and like your estimated date of production better. I have to get one of those build cards from Chrysler Historical...Pics are at: http://www.facebook.com/photo.php?fbid= ... 0937835961 (have to log in to facebook to access...Sorry- have to get another photohost & post)
DrDiesel
Private 1st Class
Private 1st Class
My garage: Dodge WC54
UAZ-469b
SKP m/42
Post by DrDiesel »
WC54 81662054 no buildcard yet.
A furore Normannorum libera nos, Domine
GoranWC51
My garage: 1945 Dodge WC51 (Febr 12 1945)
1945 Bantam T3 or Willys MBT
Post by GoranWC51 »
Tjenare Doktorn,
The build card can take up to a couple of months before you get it from Chrysler. I guess the pile up the applications and go through the bunch once every two weeks or so...
Don't forget to post you build card once you get it.
Göran N
Lidingö
Goran Noren
Dodge WC51 1945
Built: 2/12/1945
Marked as an ambulance of the
Willys MBT
ACM no 57482
Manufactured: July 1943
divingrocks
1943 WC54 Donor
DrDiesel wrote:WC54 81662054 no buildcard yet.
728671 may be a good registration number for your ambulance
jeff
My garage: 1942 Willys MB
1942 WC-54
1952 M100
Re: 3/4 Ton Database of 325 known
Post by jeff »
Rocks, found this plate under years of paint. It looks like 4239-11024?, it's really beat-up. My WC54 has a frame # 81551926,just want to add this info to your data base. Jeff
Phil P
My garage: 1944 Leyland Hippo MKII 6x4 GS 10 tonner
1944 Willys MB
1937 Sunbeam bicycle
1942 Ford GPW
Post by Phil P »
Hi Divingrocks.
325!!? Did you ever think what you might have started? Only another 167,000 WC51 and 52 or so to go according to the data I've got.
Phil
'Spirit of USS Arizona'
Feb '42 Ford GPW 'Yella Boyd'
divingrocks
1943 WC54 Donor
well, I have only collected info on survivors, not full production...a mere .01 percent of the 300,000 produced ain't bad!
Newton
My garage: 1942/3 WC51 - undergoing 'gradual' restoration.....
Re: 3/4 Ton Database of 326 known
Post by Newton »
Hi there..
Only just got around to posting my details....oops!!
Type - WC51
Chassis - 8160468
Reg. no - 2113889 (stamped onto chassis under chassis number)
Engine - T214-207559 (with further rebuild stamps/plates of 3361-52-22 and 461-00 RA / date of delivery 12-52
Personally I think it is either VERY late Dec 1942, or VERY early Jan 1943.
Hope this is of use..
Gareth
GoranWC51
Post by GoranWC51 »
Hi Gareth,
You wrote: "Chassis - 8160468" - there seems to be a number missing there. My frame number 81741448, 8 digits long.
The best way to get an exact production date is to send 25 USD (Cash in an envelope is OK, I sent money that way. There's a minute risk that the cash will disappear on the way, but it's never happened to me) to Chrysler Corp and get the build card for your vehicle. Link here:
http://wpchryslermuseum.org/newsroom.do ... 90&mid=135
Goran N
Goran Noren
Dodge WC51 1945
Built: 2/12/1945
Willys MBT
ACM no 57482
divingrocks
1943 WC54 Donor
Newton,
Yes, please provide the eight digit!
Newton
Re: 3/4 Ton Database of 327 known
Post by Newton »
Oooops!!!
Sorry guys... you spotted the 'intentional error'!!!!
The 8-digit number is 81604608
Cheers all,
Gareth
