1942-Wayne Works pic's & list
Re: 1942-Wayne Works pic's & list
G,Day all .Try , TM 10-1199 Section .Body group 18 Ambulance . Portrayal press might have copy ,or alternatively , i think Mike Kelly has a CD with this Tm on it . Ray .
divingrocks
My garage: 1942 WC54 Project
1943 WC54 Donor
Post by divingrocks »
bumped for greg alexander
Greg Alexander
Post by Greg Alexander »
Brian, thanks for bumping this thread.
Does anyone have the dimensions or additional specs on the "Appleton Mfg Spotlight"? I guess what I'm really looking for is the diameter of the Appleton vs the Unity Spotlights.
I currently have a "Unity" Spotlight on my ambulance, which I thought was the correct version for the WC-54, but according to the above parts list, Wayne Works didn't use the Unity Spotlight.
divingrocks
1943 WC54 Donor
Greg,
The appletons are the same size as the Unity you installed, but look a little different. The best example of one that I have is an Appleton Series 90, which was never chromed, rather painted brass. I hope this helps.
divingrocks
1943 WC54 Donor
bump for Phil62
rgus
My garage: 1942 CCKW 129,XXX
1943 WC-54 81635383
1943 GPW 146954
1945 WC52 818682 "MO"
1943 WC63 82009972 "BIG MO"
1944 CHECKER 1 TON TRAILER
Post by rgus »
Here is a question for you WC-54 experts. When I tore the tool boxes out of my parts vehicle, right close to the floor there was an extra hole. I found one little L type strap bracket in the ambulance. Was there origionally one each mounted to the bottom edge of the tool boxes right below the footmans loops?
wc 9 and 12 owner
Post by wc 9 and 12 owner »
there should be 2 footman loops per box. One should be the L double loop and the other the single
General Chesty Puller
rgus
1943 WC-54 81635383
1943 GPW 146954
Post by rgus »
There was only one that I found;
42WC-54
Post by 42WC-54 »
Here's a picture.
rgus
1943 WC-54 81635383
1943 GPW 146954
Post by rgus »
Where those were placed I bet they got stepped on a lot and broken. Anyone have any extras? Where did you locate the flooring material?
Greg Alexander
Very interesting. I bought my tool boxes seperately and they came with only a single Footmans Loop on all of them. I had never seen the double loop style until now. I wonder if they changed the design later in the war? I agree with RGUS that they sure look prone to being broken. Somewhere I have a Technical Bulletin that showed how to modify the lower loop, moving it up like two inches. I looked for it briefly tonight and will dig further. I know I installed mine as per the instructions in the modification, but I don't recall seeing it with a double loop in the diagram.
Another deep WC-54 Mystery to be solved. Yahoo!
42WC-54
Post by 42WC-54 »
Go back to the first post under this topic.
The Wayne Works WC 54 interior pictures & parts list you’ll see
Part #7353 loop floor strap bottom & #7849 loop floor strap.
Also if you have TM 9-808 dated 1/31/1944
Pages 332-333 interchanging bracket positions ambulance.
As long as a stretcher would be folded up there you step on stretcher first.
Mine fortunately survive 69 years..
wc 9 and 12 owner
Half tons also used them. I was given 4 by a fellow forum member but know someone that made 4 from a price of round stock and a peice of flat stock. He said it wasn't to bad to make them
Wc-51OHA
My garage: 1943 WC-51
1943 WC-54
1943 MBT 1/4 trailer
194? wooden 1 ton trailer
Post by Wc-51OHA »
In one of the manuals there is a modification that moves the two brackets located at the rear door tool boxes because they would get caught by the foot of the stretcher when they were loading a patient. They would have to lift it over the double loop bracket. I will look it up when I get home from work and find the manual number and page.
Don
Don Shupe
1943 WC-51
1943 WC-54
194? wood body 1-ton trailer
Greg Alexander
42WC-54 wrote:Go back to the first post under this topic.
Ah Hah! That's where I saw the modification, TM 9-808. I didn't notice the double loop bracket.
Can anyone post a picture and dimensions of a bare bracket (without strap)
I am sure I can duplicate them.
