Inner W.S. weather stip corners
How should the 90 degree corners on the inner windshield weather stip be made? On my first try, I just pulled the weather strip around the corners, but that left a gap. I have been told to cut the pieces at 45 degrees and glue then together with a black silicone sealer. Thanks for any ideas!
1943 WC-54 81635383
1943 GPW 146954
1945 WC52 818682 "MO"
1943 WC63 82009972 "BIG MO"
Weather strips
Where did you purchase your inner windshield inner strips? The ones from Midwest are too big, the ones from VPW are too small.
1944 WC-51
1944 WC-62
1943 M-20
G-518 Ben Hur
1943 352 CCKW
M-55 Quad Mount
1942 WC-53 Carryall (Not running)
1943 Water Ben Hur (Needs total restoration)
1944 M-14 Directors Trailer
1944 WC-62
1943 M-20
G-518 Ben Hur
1943 352 CCKW
M-55 Quad Mount
There was no black silicone in WWII.
I have used John's weatherstrip on the WC Windshield frames, we are talking opeb caps here, I presume, it goes on perfect, but takes time and patience, about an hour. 45 Degree joints at the lower corners are the norm, and I have seen industrial staples used , one each, across the mitre, on WWII windshields years ago. It is not necessary.
Guys:
I had gotten weatherstripping for the rear glass (hatch) of my Carryall from VPW. I paid extra for it too (IMHO). It was the wrong stuff. Unfortunately, the glass shop guy tossed the original stripping before I got the replacement. He also said I had the original glass/stripping on the hatch. I ended up having to get new glass cut to make what I got work. The glass is larger than the original & hides all the care I took to make sure the curves around the openings were right. I really wish they woulda kept the old stuff as I'm sure VPW woulda made things right.
The inner WC Windshield frames may not all be from the same manufacturer, as the Army stocked replacements. I have seen at least 3 types of Inner WS Frames over the years, the grooves differ slightly, and that is enough to cause replacement weatherstrip to please some, but not all. The Inner WC WS Frame is the same as used on CCKW, Studebaker, and M-1 Kenworth Open Cab, and also the 5 Ton COE 4X4 Autocar and Federal. They all used the same Ordnance Part No.
It is difficult 60 years later to have perfection for those slight differences in manufacture.
