Hi What size hub/wrench/socket do i need for the back axle on my '44 WC51 to get the inner oil seal out?
Rupert
Hub Wrench
Since the nut is octagonal, a standard socket will not work. Most auto parts stores have the correct wrench available for sale. It will not be cheap - $20.00 or more the last time I had to buy one. It should fit a nut that is 2-1/2 inches across the flats. It is a loose fit as you do not need to tighten the nut very tightly.
1943 WC-54 81635383
1943 GPW 146954
1945 WC52 818682 "MO"
1943 WC63 82009972 "BIG MO"
