Throttle linkage
Ken J
194? Ben Hur Trailer
Throttle linkage
Post by Ken J »
Hi All:
I will be reassembling my WC-1 next month (!).
Unfortunately, the engine was pretty stripped, and I don't really know how the throttle linkage goes together.
I was wondering if anyone out there could send me a few pics showing the linkage from the pedal to the carburetor??
THANKS in advance!
-Ken
brian
Post by brian »
http://community.webshots.com/user/sudi411
my pics of wc-4.
the gas pedal is connected to the push rod,
the push rod is connected to the bell crank,
the bell crank is connected to the turnie rod,
(which is bolted to the back of the bell housing)
the turnie rod is connected to the pivot pin,
the pivot pin is connected to the push rod,
the push rod is connected to the the double bell crank,
the double bell crank is activated by the springy thingy,
the springy thingy is attached to the removable floor board,
whith a cotter pin,
the other end of the bell crank is attached to the push rod,
the push rod is connected to the carburator.
and zoom zoom happens,
but not without the govener,
BB
wc-4
Guest
Post by Guest »
YOU DO THE HOKIE POKIE .....AND THATS WAHT'S IT'S ALL ABOUT
Ken J
Post by Ken J »
Thanks Brian, I'll check that link next.
It sounds as if you say I need the governor- I had intended to skip that for now, since I don't have one.
Isn't that device used for limiting engine speed? If so, then the civilian versions of this engine wouldn't have that, or yes?
