I admit I know nothing about front ends. My front wheels can move a bit when jacked up. Is there an acceptable amount of play? The truck drives straight, handles well, and no shimmy at 40mph. My truck is a '44
Brent
Acceptable play in front wheels WC52
1944 WC-52
1945 Willys MB
1945 Willys MB
To go by the English test rules, when jacked up the wheels should not wobble from top to bottom or side to side. Sounds like the bearing needs just a gentle tweack. Alowable play in a 4x4 sterring wheel is 1 1/2 inch before the wheels start to turn. It would be worth taking the front hub off and just checking over. The biggest problem is the size of the nut that holds the bearing in, it is a large box spanner job. Its an easy job once you have the tool. The other way is to put a blunt chisel against the nut and tap with a rubber hammer.
Having checked the book of words. The Dodge engineers kept to the Kiss priciple. Back off the locking nut. Tighten the inner adjusting nut up tight, back off 1/6 of a turn . Installl the nut lock. If the wheel still wobbles after this replace the bearing. nice to have a vehicle designed to be fixed.
Working manual if you don't have one. Military Media CD no 1 077421-1 has the manuals plus all sorts of other interestin stuff.
