thanks
Dan in NM
505-269-2056
Where is the link to HOW TO PUT A TOP IN A CARRYALL???
- DaninNM
M-18 Hellcat, M8, M16A1, USMC Mules, M1 57mm cannon, M3A1 Scout Car, WC26, Chenowth FAVs, Ben Hur, CCKW tipper, G506, GPW, Kawasaki KSR250, M416s, M151A1, T17E1 Staghound
- Bert
- General
- My garage: 1943 Dodge WC-51 "old bets"
1945 Dodge WC-62 - Location: the Netherlands
If you have a copy of an original Dodge Maintenance Manual you will find a section in it describing in detail how to put the top on. I used those directions for my Carryall and everything went smoothly. Only took about an hour by myself.
Would have been quicker but I decided to improve on Dodge design and put silastic in the channels to ensure 100% waterproof. Because the lock rubber relies on pinching into the channel the wet silastic effectively lubricated it and it kept popping out. Had to get a whole bunch of heavy weights to sit on the rubber as I tapped it down until the silastic started to dry.
