what are the 4239 meanings,, the 39 means ???
what are the last 2 digits of the 4239 mean, 42 is 1942, 39 desinates it to be what?? i can remember the breakdown of the 19 29 39 etc.. jc
check out this site will tell you a whole bunch .
39 is ambulance
Bill
http://users.beagle.com.au/mtrpool/
39 is ambulance
Bill
xx49 is the carryall identifier
I don't have a xx39 cab code here Jeff.
G
G
stoll this from the ww 2 dodge motor pool hope he doesn't mind
Bill
10 = flat face cowl
12 = closed cab
19 = reconnaissance
29 = radio reconnaissance
39 = ambulance
49 = carryall
62 = closed cab
66 = express body with transverse rear seats
76 = express body with no rear seats
90 = flat face cowl with bucket seats
Bill
10 = flat face cowl
12 = closed cab
19 = reconnaissance
39 = ambulance
49 = carryall
62 = closed cab
Hmmm, I coulda swore that 39 was for Carryall. Nope, I was wrong.
Bill:
Here's the link; http://www.volocars.com/news30.html , The dates are wrong, it's the 26th & 27th of August. It's closer than Fairfield by a hundred or so miles.
Bill:
- Bert
- General
- My garage: 1943 Dodge WC-51 "old bets"
1945 Dodge WC-62 - Location: the Netherlands
thanks there is a questionalable truck,, in play,
http://www.members.cox.net/acfarer/m37.jpg
this one has numbers, 4239
My wc11, are numbers 4153, 53 is a panel,,, i would guess,
- Private
Hello All
I've just started my adventure with WC 52 and I see there are a lot of experts in this forum.
Can anybody help me please, I'm trying to find out what my truck body tag means. It seems to be unusual, as I've seen that they use to have 8 digits like xxyy - zzzz.
mine have 10 digits. 4290 - 163539 can anybody tell me what it means ?
according to frame number It's late '44 truck.
numbers
42 90 means--1942
4290- flat faced cowl, open cab
163539, production number, its the 163 539 off the assembly line,,
which does make sense to me? maybe it does,, jc
it may be one of the export ones,,, norweigean
- Private
Thanks for Your fast replay,
certainly I've bought my truck from Sweden.
I was just wandering why there is such a difference in year of build.
As You said body tag shows it's 1942, but frame number - 81749641 indicates it was end of 1944 and it has 12 Volt installation, wooden cargo bed and shorter left side. It seems like both of this tags were originally there and nobody replace them.
Have You got any ideas ??
- Bert
- General
Probably been rebuild some time. If you contact Chrysler you can get a build card wich will tell you the original body and engine number.
http://ww2dodge.com/wiki/Build_Records
4290 does not mean it is a 1942
The way the body tags work is that they mark the start of a given body type. 4290 is an open cab body that was started in 1942. The body tags for WC-51s were 4290 from 1942 to 1945.
The way you tell the year is the numbers after the 4290- those numbers can be compared to other trucks to see where yours falls. As you have a high number I would guess it is original to your 1944 truck.
I wrote a page about body tags on Power Wagons, the numbering is not exactly the same, but the same theory applies.
Look here to see it:
http://t137.com/registry/help/bodytags/bodytags.htm
I hope this helps.
Eric
I hope this helps.
Eric
