I'm ready to install the outer seal on the windshield frame on my WC-54. Does the smooth side of the seal go to the inside or the outside? Should I use adhesive or just lock it into the channel?
Any suggestions would be appreciated.
WC-54 Windshield frame outer seal
- My garage: 1943 WC-51
1943 WC-54
1943 MBT 1/4 trailer
194? wooden 1 ton trailer - Location: Salisbury, NC
Don Shupe
1943 WC-51
1943 WC-54
194? wood body 1-ton trailer
1943 WC-51
1943 WC-54
Re: WC-54 Windshield frame outer seal
It will taper one way so it will only look right installed that way. I just glue them in with the screen on the vehicle, and pull the screen almost shut to hold it in place till the glue sets.
There is a small pressed ridge on the face of the cowl and the seal should go right up to that. Normally a seal that is in good condition and leaking is on a badly-adjusted screen - too high, too low, not centred side to side, or too far "in" or "out" of the vehicle.
1943 WC-54
Thank you
Don Shupe
1943 WC-51
1943 WC-54
1943 WC-51
1943 WC-54
