Dodge WC12
Dodge WC12
Post by Lang »
Photo test.
WC12 taken today.
dashtp40
My garage: WC-3
Re: Dodge WC12
Post by dashtp40 »
Lang,
I like it, looks great
Vista52
Re: Dodge WC12
Post by Vista52 »
Very nice!!
A great looking restoration. Are the wood slats on the bed sides an exotic Aussie hardwood?
Re: Dodge WC12
Post by Lang »
The wood is Merbau or Kwila. A tropical hardwood with a beautiful tight grain oily finish. Used widely in Australia for exterior decking and railings. Very heavy but it does not weather and lasts forever.
MIKEN
Re: Dodge WC12
Post by MIKEN »
VERY VERY NICE. :thumbup:
Re: Dodge WC12
Post by Lang »
Found a rear photo showing the woodwork. Rear reflectors have now been replaced with marble type.
dashtp40
My garage: WC-3
Re: Dodge WC12
Post by dashtp40 »
Lang,
The natural wood sure looks nice. I've never seen bows like those, the hump on the top is a good idea, are they metal?
Re: Dodge WC12
Post by Lang »
I have a new set of the steam bent early bows but I think they look terrible (like a John Wayne wagon train).
I decided to make a set out of square tube to the shape of the later flat-top style but the flat top not only looks a bit ordinary it guarantees the water will collect in two big puddles on top. So a couple of minutes on the band saw and I have what I hope will be both a nice looking shape for the canvas and have rain-shedding capability. Might even run a ridge pole yet.
I did not have any way of bending the square tube without distorting it so resorted to lobster-tail cuts and welding to the same radius as an original Dodge corner. A bit of grinding and a fingerful of Bondo and they look like mandrel bent corners.
Dozerman51
Re: Dodge WC12
Post by Dozerman51 »
Great looking Restoration. :thumbup: Let’s see some photos of the cab interior and engine compartment. Have you been able to find the 4.3 ratio R & P’s you were looking for a few months ago?
Dozerman51
Re: Dodge WC12
Are those PW/M-37 wheels that are on your truck? If so, I was under the impression that those wheels should not be used with the smaller 750-16 tires?
Dozerman51
Re: Dodge WC12
Here are some photos of your trucks older or younger sibling depending on the serial number.
Re: Dodge WC12
Post by Lang »
Yes the wheels are M-37/PW style.
I have a set of 7.50 non-directional tyres on original 1/2 ton wheels for show use.
The photos show it with its wider wheels and radial tyres of the same diameter. They are a little bit wider than the 7.50 but ride and handle so much better on long trips. The safety factor is greatly increased as anyone who has driven the non-directional pattern on wet bitumen roads can attest - no more exciting tail break-away if pushed around a corner hard in the rain.
That hood number is original and was plainly visible when I bought the truck complete and running (sort of) in Texas. The dash data plate and chassis number match and the build card supports the army number dating so I feel confident it is not a hood off a different vehicle.
Still in the market for the two 4.3:1 ring and pinions. Any leads greatly appreciated.
Some interior photos a bit dirty from last trip and trying to get those useless vacuum wipers going again, again......
To answer the question before it is asked. Yes, there is a winch instruction plate on the lid. I havea full field winch kit (chassis extensions. PTO shafts etc) but figured I really do not need another 100kg sitting over the front axle at this stage. The data plate is original and untouched. The small plates were illegible so two repros.
I went mad with insulation sticking dynamat over the entire inner surface (floor, firewall, roof, doors) then on top of that put 3" glass wool insulation behind every panel, including roof lining. This Dodge is as quiet in the cab as a brand new RAM!
June J
My garage: 1942 Dodge WC 53
1960 M38A1 Nekaf
Re: Dodge WC12
Post by June J »
Looks superb Lang!
Dozerman51
Re: Dodge WC12
[imgImage][/img]
Dozerman51
Re: Dodge WC12
well I Guess I need to resize the photos. at least I got one to work. LOL.
