Lubrication on Combat Rims?
G. Miskovsky
Post by G. Miskovsky »
All,
In the process of changing out my tires on the WC51. The rims came apart but stuck to the tire which required a lot of soapy water and WD40 to loosen up. Has anyone ever used any kind of lube to keep this from happening?
AIRBORNE ALL THE WAY!
Gus
'42 WC-51, '43 Ben Hur
dashtp40
My garage: WC-3
Re: Lubrication on Combat Rims?
Post by dashtp40 »
Hi G,
We used to put baby powder in light aircraft tires to keep the tubes from sticking to the tires but I can't see that working between the tire and the tube. As you probably know I don't think any type of petroleum product would be good for the tire. I'm thinking some type of silicon spray or graphite product, then whatever was applied between the tire and rim I would think some would get thrown out from the wheel rotation. That's my 2 cents worth.
FrankUSMC
Post by FrankUSMC »
let the Grandkids worry about it when they change the tires next time...
One of the few, Frank USMC RET
ng19delta
Post by ng19delta »
I actually put carnuba wax on to see if that works!
G. Miskovsky
thanks all !
Gus
i have used silicone based lubricant for that purpose. silicone based wont rot the rubber. there is products in the truck tire world designed for this issue as well. I dont remember the names.
G. Miskovsky
thanks!
Gus
Washing-up liquid fairly standard around here
