outer windshield frame to cowl seal
SteveJ
My garage: 1943 Dodge WC52
1986 Armstrong MT500EC Canadian Military Dispatch Motorcycle
Post by SteveJ »
Hi guys
I just got a new W/S frame to cowl seal for my Aug 1943 WC52. The old one in there is a rubber flat blade type seal and the new one is a rubber bulb type seal. Was there a change in the part or is the old one I have in there incorrect?
1943 Dodge WC52 8)
zepher11
Re: outer windshield frame to cowl seal
Post by zepher11 »
The one I used for my WC52 was wrapped in canvas and wasn't rubber.
Zeph
G,Day Steve . I think Zeph is right . The early ones were Rope covered in canvas . Later ones or replacement were probably like Jeep seals ,t rubber . I don,t thing that it would matter that much ,so long as it keeps the water out .I would think that the early ones made from canvas would retain water and probably rust out the window or cowl ,or both . Ray
SteveJ
Post by SteveJ »
Thanks for the replies guys, I guess Ill fit this one and see how it works.
1943 Dodge WC52 8)
JBizal
Post by JBizal »
You guys are off a bit. Early on the seals were rubber. As the war went on and rubber became a critical supply material, alternate materials came into play, hence the canvas type. The rubber ones that we are supplying are made from an original same off an NOS windshield frame.
Regards
John
MWM, Inc
SteveJ
Post by SteveJ »
Thanks John
SteveJ
1943 Dodge WC52 8)
JBizal wrote:You guys are off a bit. Early on the seals were rubber. As the war went on and rubber became a critical supply material, alternate materials came into play, hence the canvas type. The rubber ones that we are supplying are made from an original same off an NOS windshield frame.
Regards
John
MWM, Inc
John has described it correctly. That seal, plus a number of others like the front fender to cab infill, were changed from rubber to canvas. I think this happened slightly later than the change from leather to canvas for things like seat covers, armrests, and tailgate chain wraps.
wc63-1944
My garage: 1944 WC63 Dodge
1957 M201 Hotchkiss
1950's Pollynorm Jeep Trailer
Post by wc63-1944 »
Sorry to jump in but, could I ask how is the canvas or rubber seal are fixed to the screen please?
Cheers,
Chris.
G,Day Chris. The canvas ones have a inner core of rope , covered by canvas, then a smaller core on the outside of the larger core . This then slides into the retaining notch on the bottom of the wind shield . Imagine a figure 8 .With on pierce , 1/2 in and the other half 1/8 in . this 1/8 part of the seal then slides into the retainer on the bottom of the wind shield . Hope this explains it . Ray
wc63-1944
1957 M201 Hotchkiss
Post by wc63-1944 »
That explains it great Ray, thanks.
I didn't know if there was another type of fixing as my outer screen doesn't have the notch in it. I'm not sure if the bottom part of my screen has been replaced sometime in the past.
Cheers,
Chris.
