Engine Sump Leaks
June J
My garage: 1942 Dodge WC 53
1960 M38A1 Nekaf
Engine Sump Leaks
Post by June J »
Hello folks,
I have a persistent oil leak at the "chin" on the front of the engine oil pan/sump. Its definitely not the front crankshaft seal, and its not the timing cover gasket, I'm absolutely sure its the cork insert at the front of the oil pan/sump.
I am looking for any tips on getting this right, I have been careful to cut the cork inserts to the prescribed 1/8"- 1/4" protrusions but the damn thing still leaks. Anyone got any magic solutions???
Ian (newly retired :-) )
jim lee
My garage: M37
Re: Engine Sump Leaks
Post by jim lee »
Bolts holding the front stuff of the engine to the block. I had issues there with a fresh rebuilt engine. Had to pull it back out and seal the threads.
-jim lee
g,Day Ian . You shoudn,t be playing with Dodges . You should be out in the Garden with June, removing weed,s :lol: :lol: .All old dodge, s leak . Just put some kitty litter on the floor to soak up the mess . Ray
June J
1960 M38A1 Nekaf
Post by June J »
G"day Ray, :twisted:
you'r such a helpful chap :lol: :lol: But you need to be consistent
One day your berating me for not having the Carry All on the road, now your telling me to pull weeds. :roll:
Its a real pain in the butt though, there's a fired egg sized puddle every single time I run it up. :twisted: :twisted:
June J
1960 M38A1 Nekaf
Post by June J »
Hi Jim,
I assume you mean the 3 bolts that go into the removable bridge on the bottom for the timing cover?
Many thanks
did you retorque the pan?
June J
1960 M38A1 Nekaf
Post by June J »
Hi guys,
well I removed the oil pan and found that the front cork gasket had been slightly displaced during the installation so that explained the leak. While I was there I replaced the floating pick up and pick up tube (had to drop the front axle to clear the pick up tube but thats a whole new story) as the float was pretty battered. So far, so good so far as the leak is concerned.
