Cab Mounting
1943 WC-54 81635383
1943 GPW 146954
1945 WC52 818682 "MO"
1943 WC63 82009972 "BIG MO"
Cab Mounting
I just sat the cab back on it's frame on my WC63 and or the life of me I cant be sure of the bolt patern. I am thinking the springs go on both back and the drivers side front and the bolt on the passenger side front. Is this correct?
- My garage: 1944 WC63 Dodge
1957 M201 Hotchkiss
1950's Pollynorm Jeep Trailer
Re: Cab Mounting
Hi Rgus,
The springs go on the two rear mounting bolts and the passengers side mounting bolt, the drivers side is the (5/8" x 18 x 3 1/4") fixed bolt.
Cheers,
Chris.
Cheers,
Chris.
1943 WC-54 81635383
1943 GPW 146954
Re: Cab Mounting
I wasn't sure so glad I asked
Thanks Chris
Thanks Chris
Re: Cab Mounting
The reason for the large bolt with no spring being at the drivers side forward position is to stabilise the area where the pedals and steering column come through the floor.
