Well, I finally have the bed planks for my 41. They are planed to 1 inch and ready to cut to size. Just want to make sure I don't cut wrong. The forum shows in other conversations that the planks should be 8 inches wide and 78 inches long. Does this seem correct to you? The box is at the body shop so I can't test fit. All advice welcome
Rick
Cutting bed planks help
Re: Cutting bed planks help
Measure twice, cut once.
Regardless of what anyone says or what drawings you have I STRONGLY advise you to go to the shop and measure the actual length on your body. They may not all be the same as different fittings/fastenings or minor body variations could see you cursing and redoing something.
Six 8" planks sounds about right. Remember that later trucks had the same size made from cut and glued random-width boards though. Length was whatever the body was.
Not sure abut the 1" though. I remember civilian bed boards were slightly thinner and the military ones slightly thicker, but not the actual sizes.
